Uniprocessor Tests in SMP Configuration
Joel Sherrill
Joel.Sherrill at OARcorp.com
Mon Feb 24 08:09:39 UTC 2014
On Feb 24, 2014 2:17 AM, Gedare Bloom <gedare at rtems.org> wrote:
> Any of 2, 4, and 5 could be made into reasonable GSoC projects if we
> get accepted as an org?
> On Sun, Feb 23, 2014 at 5:14 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > Hello,
> > I would do the following.
> > 1. Implement the thread deletion on SMP. I will work on this after the
> > profiling.
> > http://www.rtems.org/wiki/index.php/SMP#Thread_Delete.2FRestart
> > 2. Use alternatives to task variables for all RTEMS support components, e.g.
> > the file system environment. Here we can use __getreent() for example with
> > struct S {
> > struct _reent reent;
> > rtems_user_env_t env;
I am missing some detail here. Can you provide details?
> > POSIX keys should be moved outside the RTEMS_POSIX_API scope.
I almost completed this on the flight over to Munich. Just needs a bit more testing in different build configurations.
> > 3. Disable the task variables via pre-processor on SMP and remove the
> > run-time check.
I started this but it will break the code that uses them when configured for SMP.
> > 4. Add condition variables to the Classic API.
This is beyond airplane coding.;)
> > 5. Use alternatives to disabled preemption for all RTEMS support components,
> > e.g. bdbuf.
We need to make a list of these and propose alternatives. GSOC project possible
> > 6. Disable RTEMS_PREEMT via pre-processor on SMP and remove the run-time
> > check.
> > We (= embedded brains) have currently only a budget for 1.
> > Sebastian Huber, embedded brains GmbH
> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > Phone : +49 89 189 47 41-16
> > Fax : +49 89 189 47 41-09
> > E-Mail : sebastian.huber at embedded-brains.de
> > PGP : Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > rtems-devel mailing list
> > rtems-devel at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140224/d5a139ce/attachment.html>
