Proper solution for "cannot move location counter backwards" when building tests?
Sebastian Huber
Fri Feb 14 07:52:12 UTC 2014
Hello Peter,
On 2014-02-13 23:11, Peter Dufault wrote:
> I'm testing the phycore_mpc5554 against the latest head, not too successfully.
which issues do you have?
> One hopefully easy problem is that with tests enabled I get this problem building file system tests, including fsdosfsname01:
> linkcmds.base:329 cannot move location counter backwards (from 4002c564 to 40010000)
> There's a thread about this last November ("Powerpc/mpc55xxevb build failure") with the suggestion that this be conditional on BSP_SMALL_MEMORY. I don't consider 8MB of memory small, but I'm showing my age, the younger people are spitting out their lattes at that.
I think the problem is the flash size. How big is it?
> What's a proper solution? Should the mpc55xxevb be marked BSP_SMALL_MEMORY and the test made conditional on that? I'm using a bad solution, "make -k".
> Looking forward to 4.11 release ASAP but with a fully-functional phycore_mpc5554 -
> Peter
> Peter Dufault
> HD Associates, Inc. Software and System Engineering
> rtems-devel mailing list
> rtems-devel at rtems.org
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
