Status of phycore_mpc5554 with latest RTEMS and RSB built tools
Peter Dufault
dufault at hda.com
Fri Feb 21 11:01:19 UTC 2014
On Feb 21, 2014, at 05:35 , Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 2014-02-21 11:31, Peter Dufault wrote:
>> On Feb 21, 2014, at 05:17 , Sebastian Huber<sebastian.huber at embedded-brains.de> wrote:
>>>> The preempt task is supposed to delete itself, but it cannot do this action
>>>> since it blocks on the puts(). Now the main thread continues and fails due to
>>>> the not deleted preempt task.
>>>> One workaround for this is to disable interrupt driven console output.
>> Is there a POSIXly correct way to wait for I/O to drain in a single thread?
> I am not aware of a bullet proof solution. This issue is on my list for
> several years now, but it never had a high enough priority.
I forgot to ask the important question: What happens when you increase the number of tasks to e.g. 8? SP02 still didn't run, when I broke in with the debugger it was always in the idle task.
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
