Status of phycore_mpc5554 with latest RTEMS and RSB built tools
Sebastian Huber
Fri Feb 21 12:16:56 UTC 2014
On 2014-02-21 12:01, Peter Dufault wrote:
> On Feb 21, 2014, at 05:35 , Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> On 2014-02-21 11:31, Peter Dufault wrote:
>>> On Feb 21, 2014, at 05:17 , Sebastian Huber<sebastian.huber at embedded-brains.de> wrote:
>>>>> The preempt task is supposed to delete itself, but it cannot do this action
>>>>> since it blocks on the puts(). Now the main thread continues and fails due to
>>>>> the not deleted preempt task.
>>>>> One workaround for this is to disable interrupt driven console output.
>>> Is there a POSIXly correct way to wait for I/O to drain in a single thread?
>> I am not aware of a bullet proof solution. This issue is on my list for
>> several years now, but it never had a high enough priority.
> I forgot to ask the important question: What happens when you increase the number of tasks to e.g. 8? SP02 still didn't run, when I broke in with the debugger it was always in the idle task.
It is the same problem: blocking on output. As a quick hack you can add
CPU_CFLAGS += -DTESTS_USE_PRINTK
to the *.cfg file of your BSP.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
