OS Web Monitor
    Chirayu Desai
    chirayudesai1 at gmail.com
    Sun Jan  5 06:31:45 UTC 2014
I've uploaded two patches for oswebmonitor, [1] and [2]
[1] fixes a minor issue with bin2c being installed as rtems-bin2c
[2] removes support for GoAhead
[1]:
https://gist.github.com/chirayudesai/d8e72a999cb02e2d9dcd/raw/a869794c687cfbf9575efe8195245a7a4ac8992d/0001-make-bin2c-is-installed-as-rtems-bin2c.patch
[2]:
https://gist.github.com/chirayudesai/d8e72a999cb02e2d9dcd/raw/55b65f128daf2ad532e83b6d44b976de51cae64c/0001-remove-support-for-GoAhead.patch
On Sat, Jan 4, 2014 at 10:01 PM, Chirayu Desai <chirayudesai1 at gmail.com>wrote:
> The source is at http://git.rtems.org/osmonweb, and an announcement at
> http://www.rtems.org/ml/rtems-users/2003/october/msg00013.html
> I wasn't able to find a wiki entry for it though.
> Anyways, I was looking at it, and here's what I noticed:
> I wasn't sure as to which version should I be building this against, so I
> went ahead and tried with the current HEAD, and it didn't work.
> I fixed some basic stuff, http://sprunge.us/fgja
> But, the problem is Simple HTTPD does not exist in the rtems tree anymore,
> it was removed:
> commit dc35201765459ae69c0becccdc4cace5ce246da2
> Author: Ralf Corsepius <ralf.corsepius at rtems.org>
> Date: Wed Jun 9 08:06:08 2010 +0000
> Remove.
> I was not able to find any more info on this, but 'git ls-tree' shows it
> in 4.10.
> I see mongoose web server in the current tree (as well as 4.10), is there
> any plan of using it for this?
> Also, there is code for supporting goahead web server in oswebmonitor, not
> used by default, where can I find a RTEMS port of that (perhaps with some
> instructions on using it)
> Looks like oswebmonitor might need to be updated for mongoose, and the
> simple httpd code could be dropped.
> -- Chirayu
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140105/2f6971a1/attachment-0001.html>
