[PATCH] lpc24xx/lpc17xx: Probe for ETHERNET PHY MII address
Mon Jan 13 12:14:10 UTC 2014
Hello Pavel,
On 2014-01-03 14:39, Pavel Pisa wrote:
> The default used address 0 is reserved by MII PHY specification
> and some PHY do not respond to it. It is possible to use
> SCANINC in MCFG register as another alternative.
> The DP83848 PHY support is added as well.
> Signed-off-by: Pavel Pisa <ppisa at pikron.com>
>   Code requires testing on alredy supported LPC24xx
>   and LPC17xx boards equipped by KSZ80X1RNL PHY.
>   .../libbsp/arm/shared/lpc/network/lpc-ethernet.c   |   83 +++++++++++++++++---
>   1 file changed, 74 insertions(+), 9 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c
> b/c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c
> index ca43143..9136860 100644
> --- a/c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c
> +++ b/c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c
> @@ -62,8 +62,11 @@
>   #endif
>   #define DEFAULT_PHY 0
> +#define DEFAULT_SELECTED_PHY 0
>   #define WATCHDOG_TIMEOUT 5
> +static int lpc_eth_selected_phy = DEFAULT_SELECTED_PHY;
does it make sense to add this to the lpc_eth_driver_entry structure?
>   typedef struct {
>     uint32_t start;
>     uint32_t control;
> @@ -232,6 +235,8 @@ static volatile lpc_eth_controller *const lpc_eth =
>   #define ETH_MCFG_CLOCK_SELECT(val) BSP_FLD32(val, 2, 4)
> +#define ETH_MCFG_RESETMIIMGMT BSP_BIT32(15)
>   /* ETH_MCMD */
>   #define ETH_MCMD_READ BSP_BIT32(0)
> @@ -1089,15 +1094,24 @@ static int lpc_eth_mdio_wait_for_not_busy(void)
>       ++i;
> +  LPC_ETH_PRINTK("tx: lpc_eth_mdio_wait %s after %d\n",
> +                 i != one_second? "succeed": "timeout", i);
>     return i != one_second ? 0 : ETIMEDOUT;
> -static uint32_t lpc_eth_mdio_read_anlpar(void)
> +static uint32_t lpc_eth_mdio_read_anlpar(int phy)
> -  uint32_t madr = ETH_MADR_REG(MII_ANLPAR) | ETH_MADR_PHY(DEFAULT_PHY);
> +  uint32_t madr;
>     uint32_t anlpar = 0;
>     int eno = 0;
> +  if (phy == DEFAULT_PHY)
> +    phy = lpc_eth_selected_phy;
> +  madr = ETH_MADR_REG(MII_ANLPAR) | ETH_MADR_PHY(phy);
>     if (lpc_eth->madr != madr) {
>       lpc_eth->madr = madr;
> @@ -1128,8 +1142,11 @@ static int lpc_eth_mdio_read(
>     int eno = 0;
> -  if (phy == -1 || phy == 0) {
> -    lpc_eth->madr = ETH_MADR_REG(reg) | ETH_MADR_PHY(DEFAULT_PHY);
> +  if ((phy != -1) && (phy <= 31)) {
> +    lpc_eth->madr = ETH_MADR_REG(reg) | ETH_MADR_PHY(phy);
>       lpc_eth->mcmd = 0;
>       lpc_eth->mcmd = ETH_MCMD_READ;
>       eno = lpc_eth_mdio_wait_for_not_busy();
> @@ -1153,8 +1170,11 @@ static int lpc_eth_mdio_write(
>     int eno = 0;
> +  if ((phy != -1) || (phy != 0)) {
>       lpc_eth->mwtd = val;
>     } else {
> @@ -1182,6 +1202,7 @@ static int lpc_eth_phy_get_id(uint32_t *id)
>   #define PHY_KSZ80X1RNL 0x221550
> +#define PHY_DP83848    0x20005c90
>   typedef struct {
>     unsigned reg;
> @@ -1230,9 +1251,41 @@ static const lpc_eth_phy_action lpc_eth_phy_up_post_action_KSZ80X1RNL [] = {
>     { 0x10, 0x10, 0 }
> +#ifdef LPC24XX_PIN_ETHERNET_POWER_DOWN
Is this LPC24XX_PIN_ETHERNET_POWER_DOWN a new BSP option?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
