OS Web Monitor
    Gedare Bloom
    gedare at rtems.org
    Fri Jan 17 14:29:26 UTC 2014
Hi,
I won't support this relocation until the build is confirmed. Thanks!
On Sat, Jan 11, 2014 at 5:34 AM, Chirayu Desai <chirayudesai1 at gmail.com> wrote:
> I have moved oswebmonitor to network-demos, preserving commit history.
> The content of the repository osmonweb.git has been added to a new directory
> osmonweb.
> The tree can be browsed at [1].
> All commits but the last 2 don't touch anything in the topdir, only add /
> modify content under the osmonweb directory.
> It does not build with 4.11 (didn't before this merge, like I said in the
> original message), and I do not have 4.10 built and installed currently, so
> as of now it is untested.
> I will test it by later today / tomorrow if time permits.
> Also, looks like the code under http/ (in network-demos) is for "test of
> GoAhead web server", which is deprecated, so it doesn't build with 4.11
> [1]: https://github.com/chirayudesai/rtems-network-demos
> On Tue, Jan 7, 2014 at 2:16 PM, Nick Withers <nick at nickwithers.com> wrote:
>> On Mon, 2014-01-06 at 09:44 -0600, Joel Sherrill wrote:
>> > On 1/5/2014 5:41 AM, Nick Withers wrote:
>> > > On Sun, 2014-01-05 at 12:01 +0530, Chirayu Desai wrote:
>> > >> I've uploaded two patches for oswebmonitor, [1] and [2]
>> > >> [1] fixes a minor issue with bin2c being installed as rtems-bin2c
>> > > I thought that was on purpose...? Not sure it should be installed as
>> > > bin2c, as that could clash with a host binary.
>> > > Are there actually any RTEMS-specifics in rtems-bin2c?
>> > No. It just wasn't packaged and it is a commonly needed utility when
>> > building
>> > up filesystem images.
>> Yeah, fair enough (I'm using it myself).
>> It doesn't seem to be packaged on either FreeBSD or Ubuntu, otherwise I
>> was gonna suggest removing it in favour of the host binary (which still
>> seems like it'd be optimal in the ideal world).
>> P.S., Cheers for the earlier clarification Chirayu :-)
>> > >> [2] removes support for GoAhead
>> > >> [1]:
>> > >> https://gist.github.com/chirayudesai/d8e72a999cb02e2d9dcd/raw/a869794c687cfbf9575efe8195245a7a4ac8992d/0001-make-bin2c-is-installed-as-rtems-bin2c.patch
>> > >> [2]:
>> > >> https://gist.github.com/chirayudesai/d8e72a999cb02e2d9dcd/raw/55b65f128daf2ad532e83b6d44b976de51cae64c/0001-remove-support-for-GoAhead.patch
>> Nick Withers
>> email: nick at nickwithers.com
>> Web: http://www.nickwithers.com
>> Mobile: +61 414 397 446
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
