OS Web Monitor
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Jan 17 15:01:29 UTC 2014
Where is the patch so I can review it?
On 1/17/2014 8:29 AM, Gedare Bloom wrote:
> Hi,
> I won't support this relocation until the build is confirmed. Thanks!
> On Sat, Jan 11, 2014 at 5:34 AM, Chirayu Desai <chirayudesai1 at gmail.com> wrote:
>> I have moved oswebmonitor to network-demos, preserving commit history.
>> The content of the repository osmonweb.git has been added to a new directory
>> osmonweb.
>> The tree can be browsed at [1].
>> All commits but the last 2 don't touch anything in the topdir, only add /
>> modify content under the osmonweb directory.
>> It does not build with 4.11 (didn't before this merge, like I said in the
>> original message), and I do not have 4.10 built and installed currently, so
>> as of now it is untested.
>> I will test it by later today / tomorrow if time permits.
>> Also, looks like the code under http/ (in network-demos) is for "test of
>> GoAhead web server", which is deprecated, so it doesn't build with 4.11
>> [1]: https://github.com/chirayudesai/rtems-network-demos
>> On Tue, Jan 7, 2014 at 2:16 PM, Nick Withers <nick at nickwithers.com> wrote:
>>> On Mon, 2014-01-06 at 09:44 -0600, Joel Sherrill wrote:
>>>> On 1/5/2014 5:41 AM, Nick Withers wrote:
>>>>> On Sun, 2014-01-05 at 12:01 +0530, Chirayu Desai wrote:
>>>>>> I've uploaded two patches for oswebmonitor, [1] and [2]
>>>>>> [1] fixes a minor issue with bin2c being installed as rtems-bin2c
>>>>> I thought that was on purpose...? Not sure it should be installed as
>>>>> bin2c, as that could clash with a host binary.
>>>>> Are there actually any RTEMS-specifics in rtems-bin2c?
>>>> No. It just wasn't packaged and it is a commonly needed utility when
>>>> building
>>>> up filesystem images.
>>> Yeah, fair enough (I'm using it myself).
>>> It doesn't seem to be packaged on either FreeBSD or Ubuntu, otherwise I
>>> was gonna suggest removing it in favour of the host binary (which still
>>> seems like it'd be optimal in the ideal world).
>>> P.S., Cheers for the earlier clarification Chirayu :-)
>>>>>> [2] removes support for GoAhead
>>>>>> [1]:
>>>>>> https://gist.github.com/chirayudesai/d8e72a999cb02e2d9dcd/raw/a869794c687cfbf9575efe8195245a7a4ac8992d/0001-make-bin2c-is-installed-as-rtems-bin2c.patch
>>>>>> [2]:
>>>>>> https://gist.github.com/chirayudesai/d8e72a999cb02e2d9dcd/raw/55b65f128daf2ad532e83b6d44b976de51cae64c/0001-remove-support-for-GoAhead.patch
>>> Nick Withers
>>> email: nick at nickwithers.com
>>> Web: http://www.nickwithers.com
>>> Mobile: +61 414 397 446
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
