OS Web Monitor
Fri Jan 17 15:08:09 UTC 2014
the top 4 commits at
https://github.com/chirayudesai/rtems-network-demos/commits/osmonweb
appear to be the ones to look at / test.
On Fri, Jan 17, 2014 at 10:01 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Where is the patch so I can review it?
> On 1/17/2014 8:29 AM, Gedare Bloom wrote:
>> Hi,
>> I won't support this relocation until the build is confirmed. Thanks!
>> On Sat, Jan 11, 2014 at 5:34 AM, Chirayu Desai <chirayudesai1 at gmail.com> wrote:
>>> I have moved oswebmonitor to network-demos, preserving commit history.
>>> The content of the repository osmonweb.git has been added to a new directory
>>> osmonweb.
>>> The tree can be browsed at [1].
>>> All commits but the last 2 don't touch anything in the topdir, only add /
>>> modify content under the osmonweb directory.
>>> It does not build with 4.11 (didn't before this merge, like I said in the
>>> original message), and I do not have 4.10 built and installed currently, so
>>> as of now it is untested.
>>> I will test it by later today / tomorrow if time permits.
>>> Also, looks like the code under http/ (in network-demos) is for "test of
>>> GoAhead web server", which is deprecated, so it doesn't build with 4.11
>>> [1]: https://github.com/chirayudesai/rtems-network-demos
>>> On Tue, Jan 7, 2014 at 2:16 PM, Nick Withers <nick at nickwithers.com> wrote:
>>>> On Mon, 2014-01-06 at 09:44 -0600, Joel Sherrill wrote:
>>>>> On 1/5/2014 5:41 AM, Nick Withers wrote:
>>>>>> On Sun, 2014-01-05 at 12:01 +0530, Chirayu Desai wrote:
>>>>>>> I've uploaded two patches for oswebmonitor, [1] and [2]
>>>>>>> [1] fixes a minor issue with bin2c being installed as rtems-bin2c
>>>>>> I thought that was on purpose...? Not sure it should be installed as
>>>>>> bin2c, as that could clash with a host binary.
>>>>>> Are there actually any RTEMS-specifics in rtems-bin2c?
>>>>> No. It just wasn't packaged and it is a commonly needed utility when
>>>>> building
>>>>> up filesystem images.
>>>> Yeah, fair enough (I'm using it myself).
>>>> It doesn't seem to be packaged on either FreeBSD or Ubuntu, otherwise I
>>>> was gonna suggest removing it in favour of the host binary (which still
>>>> seems like it'd be optimal in the ideal world).
>>>> P.S., Cheers for the earlier clarification Chirayu :-)
>>>>>>> [2] removes support for GoAhead
>>>>>>> [1]:
>>>>>>> https://gist.github.com/chirayudesai/d8e72a999cb02e2d9dcd/raw/a869794c687cfbf9575efe8195245a7a4ac8992d/0001-make-bin2c-is-installed-as-rtems-bin2c.patch
>>>>>>> [2]:
>>>>>>> https://gist.github.com/chirayudesai/d8e72a999cb02e2d9dcd/raw/55b65f128daf2ad532e83b6d44b976de51cae64c/0001-remove-support-for-GoAhead.patch
>>>> Nick Withers
>>>> email: nick at nickwithers.com
>>>> Web: http://www.nickwithers.com
>>>> Mobile: +61 414 397 446
>>>> _______________________________________________
>>>> rtems-devel mailing list
>>>> rtems-devel at rtems.org
>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
