Patch to implement pthread_getattr_np
Jennifer Averett
Jennifer.Averett at OARcorp.com
Fri Jan 17 17:22:37 UTC 2014
I'll remove the include files that are not used.
For the "register" modifier I was following the convention used in
other posix files:
pthreaddetach.c: register Thread_Control *the_thread;
pthreadgetaffinitynp.c: register Thread_Control *the_thread;
pthreadgetattrnp.c: register Thread_Control *the_thread;
pthreadgetschedparam.c: register Thread_Control *the_thread;
pthreadjoin.c: register Thread_Control *the_thread;
pthreadsetaffinitynp.c: register Thread_Control *the_thread;
pthreadsetschedparam.c: register Thread_Control *the_thread;
We can change the convention, but I think it should be consistent.
Jennifer
> -----Original Message-----
> From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On
> Behalf Of Gedare Bloom
> Sent: Friday, January 17, 2014 11:06 AM
> To: Jennifer Averett
> Cc: rtems-devel at rtems.org
> Subject: Re: Patch to implement pthread_getattr_np
> I have a couple cosmetic complaints:
> why include cpuset.h? similarly is priorityimpl.h needed for something?
> i don't think it is necessarily a good idea to declare variables with the
> "register" modifier.
> As a general comment about our score thread implementation, i do not like
> the mismatch between the_thread=Thread_Get() and
> Object_Put(the_thread); this is not relevant to your patch, just
> commenting..
> -Gedare
> On Fri, Jan 17, 2014 at 11:17 AM, Jennifer Averett
> <Jennifer.Averett at oarcorp.com> wrote:
> > The attached patch implements pthread_getattr_np().
> > Jennifer Averett
> > On-Line Applications Research
> > rtems-devel mailing list
> > http://www.rtems.org/mailman/listinfo/rtems-devel
