Patch to implement pthread_getattr_np
Fri Jan 17 17:37:59 UTC 2014
I would get rid of "register" keyword. it serves only a little
purpose, which is the compiler should complain if the address of the
variable is taken, e.g. &the_thread should cause a compiler error. g++
ignores this.
FWIW in these cases the "restrict" keyword actually might make sense
and be useful. the restrict condition should be satisfied due to
dispatch disabled.
-Gedare
On Fri, Jan 17, 2014 at 12:22 PM, Jennifer Averett
<Jennifer.Averett at oarcorp.com> wrote:
> I'll remove the include files that are not used.
> For the "register" modifier I was following the convention used in
> other posix files:
>   pthreaddetach.c:  register Thread_Control *the_thread;
>   pthreadgetaffinitynp.c:  register Thread_Control *the_thread;
>   pthreadgetattrnp.c:  register Thread_Control *the_thread;
>   pthreadgetschedparam.c:  register Thread_Control *the_thread;
>   pthreadjoin.c:  register Thread_Control *the_thread;
>   pthreadsetaffinitynp.c:  register Thread_Control *the_thread;
>   pthreadsetschedparam.c:  register Thread_Control             *the_thread;
> We can change the convention, but I think it should be consistent.
> Jennifer
>> -----Original Message-----
>> From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On
>> Behalf Of Gedare Bloom
>> Sent: Friday, January 17, 2014 11:06 AM
>> To: Jennifer Averett
>> Cc: rtems-devel at rtems.org
>> Subject: Re: Patch to implement pthread_getattr_np
>> I have a couple cosmetic complaints:
>> why include cpuset.h? similarly is priorityimpl.h needed for something?
>> i don't think it is necessarily a good idea to declare variables with the
>> "register" modifier.
>> As a general comment about our score thread implementation, i do not like
>> the mismatch between the_thread=Thread_Get() and
>> Object_Put(the_thread); this is not relevant to your patch, just
>> commenting..
>> -Gedare
>> On Fri, Jan 17, 2014 at 11:17 AM, Jennifer Averett
>> > The attached patch implements pthread_getattr_np().
>> > Jennifer Averett
>> > On-Line Applications Research
>> > _______________________________________________
>> > rtems-devel mailing list
>> > http://www.rtems.org/mailman/listinfo/rtems-devel
