compiling head for xilinx_zynq_zedboard BSP, ld:linkcmds.base:68: syntax error
Chris Johns
chrisj at rtems.org
Mon Jan 20 22:49:50 UTC 2014
On 20/01/2014 10:34 pm, Sebastian Huber wrote:
> Hello Giovanni,
> On 2014-01-20 12:06, Giovanni Macciocu wrote:
>> I'm trying to compile todays RTEMS head for the BSP
>> 'xilinx_zynq_zedboard'. I've used the following configure options
>> $ ../configure --target=arm-rtems4.11
>> --enable-rtemsbsp=xilinx_zynq_zedboard --prefix=/opt/rtems-4.11
>> $ make
>> This does not succesfully compile (linker error).
> you need Binutils 2.24.
The current RSB provides this version. Please update and rebuild your
tools to remove this error.
