compiling head for xilinx_zynq_zedboard BSP, ld:linkcmds.base:68: syntax error
Giovanni Macciocu G.Macciocu at sron.nl
Tue Jan 21 08:46:23 UTC 2014
 Thanx!, This indeed solved the problem.
Regards,
Giovanni
>>> Chris Johns <chrisj at rtems.org> 1/20/2014 11:49 PM >>>
On 20/01/2014 10:34 pm, Sebastian Huber wrote:
> Hello Giovanni,
> On 2014-01-20 12:06, Giovanni Macciocu wrote:
>> I'm trying to compile todays RTEMS head for the BSP
>> 'xilinx_zynq_zedboard'. I've used the following configure options
>> $ ../configure --target=arm-rtems4.11
>> --enable-rtemsbsp=xilinx_zynq_zedboard --prefix=/opt/rtems-4.11
>> $ make
>> This does not succesfully compile (linker error).
> you need Binutils 2.24.
The current RSB provides this version. Please update and rebuild your
tools to remove this error.
rtems-devel mailing list
rtems-devel at rtems.org
http://www.rtems.org/mailman/listinfo/rtems-devel
