xilinx_zynq_zedboard BSP, ethernet
Ric Claus claus at slac.stanford.edu
Wed Jan 22 17:22:27 UTC 2014
Hi Giovanni,
  No, it's not supported.  I've adapted the proprietary Xilinx code to work with the BSD network stack that is currently in RTEMS.  I can share that with you if you'd like, but you'd be on your own to get the Xilinx portion of it.  Unfortunately I have neither time nor funding to make a fully supportable version of this code that is acceptable to RTEMS.
	Ric
On Jan 21, 2014, at 8:41 AM, Giovanni Macciocu wrote:
> Hi all,
> I'm working with RTEMS compiled for the "xilinx_zynq_zedboard" BSP, It looks like there is currently no ethernet suppport. I've looked at the source files under "rtems/c/src/lib/libbsp/arm/xilinx-zynq" and there I don't find any files related to the ethernet peripheral. Does anody know if ethernet is currently supported by this BSP?
> Regards,
> Giovanni Macciocu, Software Design Engineer
> SRON Netherlands Institute for Space Research
> rtems-devel mailing list
> rtems-devel at rtems.org
