Installing ISR implementation for OpenRISC
Tue Jul 1 12:59:45 UTC 2014
For a "simple vectored architecture", the usual approach in RTEMS is
to implement some "set_vector()" function that will install a function
pointer in the IRQ table. This function pointer will either be called
in "rtems" mode via trampoline code (ISR_Handler) that sets up a safe
C environment, or will be called directly in "raw" mode and is
responsible to avoid trashing the preempted stack.
For the few interrupt handlers that are provided by the BSP and can
fit in 64 instructions (256 bytes / 4 bytes per insn) you can just
write directly in the IRQ table. I don't know if there are examples in
RTEMS of an API for doing so. Normally, a user just wants to install
an IRQ in "rtems" mode, since that will provide safe access to some
RTEMS directives and gives a usable C program stack.
Gedare
On Mon, Jun 30, 2014 at 7:51 PM, Hesham Moustafa
<heshamelmatary at gmail.com> wrote:
> Hi,
> I want to implement an API for OpenRISC IRQ. The hardware assumes that the
> handlers are installed at addresses 0x100 * N, meaning that every interrupt
> handler is starting at a multiple of 0x100, and each of each is of size 0xFF
> at maximum. Once an interrupt occurs, the processors jumps to the
> corresponding 0x100 * N address according to the interrupt type.
> There are some solutions I propose for the implementation of Install_ISR
> function:
> First, the ISR code text can be copied to the correct 0x100 * N address, but
> this will fail if the code text is longer than 0xFF.
> Second, the interrupt handlers at 0x100 * N can have the first instruction
> to always jumps to the next word (or any other address in the range of 0x100
> * N : 0x100 * (N+1) - 1, which is the address of the ISR that the installer
> would write.
> I would appreciate any other suggestions.
> Regards,
> Hesham
> devel mailing list
> devel at rtems.org
