[PATCH] score: PR2183: Fix context switch on SMP
Sebastian Huber
Tue Jul 1 14:18:43 UTC 2014
Fix context switch on SMP for ARM, PowerPC and SPARC.
Atomically test and set the is executing indicator of the heir context
to ensure that at most one processor uses the heir context. Break the
busy wait loop also due to heir updates.
c/src/lib/libbsp/sparc/shared/irq_asm.S | 55 +++++++--
c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S | 140 +++++++++++++--------
cpukit/score/cpu/arm/arm_exc_interrupt.S | 12 --
cpukit/score/cpu/arm/cpu_asm.S | 54 +++++++--
cpukit/score/cpu/arm/rtems/asm.h | 14 ++-
cpukit/score/cpu/no_cpu/rtems/score/cpu.h | 33 +++++-
cpukit/score/cpu/powerpc/rtems/score/cpu.h | 2 +-
cpukit/score/cpu/sparc/rtems/score/cpu.h | 2 +-
8 files changed, 226 insertions(+), 86 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/irq_asm.S b/c/src/lib/libbsp/sparc/shared/irq_asm.S
index bf2dca9..7ba06bb 100644
--- a/c/src/lib/libbsp/sparc/shared/irq_asm.S
+++ b/c/src/lib/libbsp/sparc/shared/irq_asm.S
@@ -165,17 +165,18 @@ done_flushing:
#if defined(RTEMS_SMP)
! The executing context no longer executes on this processor
- stb %g0, [%o0 + SPARC_CONTEXT_CONTROL_IS_EXECUTING_OFFSET]
+ st %g0, [%o0 + SPARC_CONTEXT_CONTROL_IS_EXECUTING_OFFSET]
- ! Wait for heir context to stop execution
-1:
- ldub [%o1 + SPARC_CONTEXT_CONTROL_IS_EXECUTING_OFFSET], %g1
+ ! Try to update the is executing indicator of the heir context
+ mov 1, %g1
+try_update_is_executing:
+ swap [%o1 + SPARC_CONTEXT_CONTROL_IS_EXECUTING_OFFSET], %g1
cmp %g1, 0
- bne 1b
- mov 1, %g1
+ bne check_is_executing
- ! The heir context executes now on this processor
- stb %g1, [%o1 + SPARC_CONTEXT_CONTROL_IS_EXECUTING_OFFSET]
+ ! The next load is in a delay slot, which is all right
#endif
ld [%o1 + G5_OFFSET], %g5 ! restore the global registers
@@ -203,6 +204,44 @@ done_flushing:
jmp %o7 + 8 ! return
nop ! delay slot
+#if defined(RTEMS_SMP)
+check_is_executing:
+ ! Check the is executing indicator of the heir context
+ ld [%o1 + SPARC_CONTEXT_CONTROL_IS_EXECUTING_OFFSET], %g1
+ cmp %g1, 0
+ beq try_update_is_executing
+ mov 1, %g1
+ ! Check if a thread dispatch is necessary
+ ldub [%g6 + PER_CPU_DISPATCH_NEEDED], %g1
+ cmp %g1, 0
+ beq check_is_executing
+ nop
+ ! We have a new heir
+ ! Clear the thread dispatch necessary flag
+ stub %g0, [%g6 + PER_CPU_DISPATCH_NEEDED]
+ ! Here we assume a strong memory order, otherwise a memory barrier must
+ ! be inserted here
+ ! Read the executing and heir
+ ld [%g6 + PER_CPU_OFFSET_EXECUTING], %g1
+ ld [%g6 + PER_CPU_OFFSET_HEIR], %g2
+ ! Calculate the heir context pointer
+ sub %o1, %g1, %g1
+ add %g1, %g2, %o1
+ ! Update the executing
+ st %g2, [%g6 + PER_CPU_OFFSET_EXECUTING]
+ ba try_update_is_executing
+ mov 1, %g1
+#endif
* void _CPU_Context_restore(
* Context_Control *new_context
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S b/c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S
index 6bde8bd..35ceccc 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S
@@ -23,7 +23,7 @@
* COPYRIGHT (c) 1989-1997.
* On-Line Applications Research Corporation (OAR).
- * Copyright (c) 2011-2013 embedded brains GmbH.
+ * Copyright (c) 2011-2014 embedded brains GmbH.
* The license and distribution terms for this file may in
* the file LICENSE in this distribution or at
@@ -32,7 +32,8 @@
#include <rtems/asm.h>
#include <rtems/powerpc/powerpc.h>
-#include <rtems/score/cpu.h>
+#include <rtems/score/percpu.h>
+#include <libcpu/powerpc-utility.h>
#include <bspopts.h>
#if PPC_DEFAULT_CACHE_LINE_SIZE != 32
@@ -257,33 +258,37 @@ PROC (_CPU_Context_switch):
/* Align to a cache line */
clrrwi r3, r3, 5
- clrrwi r4, r4, 5
+ clrrwi r5, r4, 5
DATA_CACHE_ZERO_AND_TOUCH(r10, PPC_CONTEXT_CACHE_LINE_0)
DATA_CACHE_ZERO_AND_TOUCH(r11, PPC_CONTEXT_CACHE_LINE_1)
/* Save context to r3 */
- mfmsr r5
- mflr r6
- mfcr r7
+ mfmsr r6
+ mflr r7
+ mfcr r8
* We have to clear the reservation of the executing thread. See also
* Book E section 6.1.6.2 "Atomic Update Primitives". Recent GCC
- * versions use atomic operations in the C++ library for example.
+ * versions use atomic operations in the C++ library for example. On
+ * SMP configurations the reservation is cleared later during the
+ * context switch.
#if PPC_CONTEXT_OFFSET_GPR1 != PPC_CONTEXT_CACHE_LINE_0 \
|| !BSP_DATA_CACHE_ENABLED \
|| PPC_CACHE_ALIGNMENT != 32
li r10, PPC_CONTEXT_OFFSET_GPR1
#endif
+#ifndef RTEMS_SMP
stwcx. r1, r3, r10
+#endif
stw r1, PPC_CONTEXT_OFFSET_GPR1(r3)
- stw r5, PPC_CONTEXT_OFFSET_MSR(r3)
- stw r6, PPC_CONTEXT_OFFSET_LR(r3)
- stw r7, PPC_CONTEXT_OFFSET_CR(r3)
+ stw r6, PPC_CONTEXT_OFFSET_MSR(r3)
+ stw r7, PPC_CONTEXT_OFFSET_LR(r3)
+ stw r8, PPC_CONTEXT_OFFSET_CR(r3)
PPC_GPR_STORE r14, PPC_CONTEXT_OFFSET_GPR14(r3)
PPC_GPR_STORE r15, PPC_CONTEXT_OFFSET_GPR15(r3)
@@ -329,66 +334,69 @@ PROC (_CPU_Context_switch):
#ifdef RTEMS_SMP
/* The executing context no longer executes on this processor */
msync
- li r5, 0
- stb r5, PPC_CONTEXT_OFFSET_IS_EXECUTING(r3)
+ li r6, 0
+ stw r6, PPC_CONTEXT_OFFSET_IS_EXECUTING(r3)
- /* Wait for heir context to stop execution */
-1:
- lbz r5, PPC_CONTEXT_OFFSET_IS_EXECUTING(r4)
- cmpwi r5, 0
- bne 1b
- /* The heir context executes now on this processor */
- li r5, 1
- stb r5, PPC_CONTEXT_OFFSET_IS_EXECUTING(r4)
+ /* Check the is executing indicator of the heir context */
+ addi r6, r5, PPC_CONTEXT_OFFSET_IS_EXECUTING
+ lwarx r7, r0, r6
+ cmpwi r7, 0
+ bne check_thread_dispatch_necessary
+ /* Try to update the is executing indicator of the heir context */
+ li r7, 1
+ stwcx. r7, r0, r6
isync
#endif
- /* Restore context from r4 */
+ /* Restore context from r5 */
restore_context:
#ifdef __ALTIVEC__
- mr r14, r4
+ mr r14, r5
.extern _CPU_Context_switch_altivec
bl _CPU_Context_switch_altivec
- mr r4, r14
+ mr r5, r14
#endif
- lwz r1, PPC_CONTEXT_OFFSET_GPR1(r4)
- lwz r5, PPC_CONTEXT_OFFSET_MSR(r4)
- lwz r6, PPC_CONTEXT_OFFSET_LR(r4)
- lwz r7, PPC_CONTEXT_OFFSET_CR(r4)
+ lwz r1, PPC_CONTEXT_OFFSET_GPR1(r5)
+ lwz r6, PPC_CONTEXT_OFFSET_MSR(r5)
+ lwz r7, PPC_CONTEXT_OFFSET_LR(r5)
+ lwz r8, PPC_CONTEXT_OFFSET_CR(r5)
- PPC_GPR_LOAD r14, PPC_CONTEXT_OFFSET_GPR14(r4)
- PPC_GPR_LOAD r15, PPC_CONTEXT_OFFSET_GPR15(r4)
+ PPC_GPR_LOAD r14, PPC_CONTEXT_OFFSET_GPR14(r5)
+ PPC_GPR_LOAD r15, PPC_CONTEXT_OFFSET_GPR15(r5)
DATA_CACHE_TOUCH(r0, r1)
- PPC_GPR_LOAD r16, PPC_CONTEXT_OFFSET_GPR16(r4)
- PPC_GPR_LOAD r17, PPC_CONTEXT_OFFSET_GPR17(r4)
- PPC_GPR_LOAD r18, PPC_CONTEXT_OFFSET_GPR18(r4)
- PPC_GPR_LOAD r19, PPC_CONTEXT_OFFSET_GPR19(r4)
+ PPC_GPR_LOAD r16, PPC_CONTEXT_OFFSET_GPR16(r5)
+ PPC_GPR_LOAD r17, PPC_CONTEXT_OFFSET_GPR17(r5)
+ PPC_GPR_LOAD r18, PPC_CONTEXT_OFFSET_GPR18(r5)
+ PPC_GPR_LOAD r19, PPC_CONTEXT_OFFSET_GPR19(r5)
- PPC_GPR_LOAD r20, PPC_CONTEXT_OFFSET_GPR20(r4)
- PPC_GPR_LOAD r21, PPC_CONTEXT_OFFSET_GPR21(r4)
- PPC_GPR_LOAD r22, PPC_CONTEXT_OFFSET_GPR22(r4)
- PPC_GPR_LOAD r23, PPC_CONTEXT_OFFSET_GPR23(r4)
+ PPC_GPR_LOAD r20, PPC_CONTEXT_OFFSET_GPR20(r5)
+ PPC_GPR_LOAD r21, PPC_CONTEXT_OFFSET_GPR21(r5)
+ PPC_GPR_LOAD r22, PPC_CONTEXT_OFFSET_GPR22(r5)
+ PPC_GPR_LOAD r23, PPC_CONTEXT_OFFSET_GPR23(r5)
- PPC_GPR_LOAD r24, PPC_CONTEXT_OFFSET_GPR24(r4)
- PPC_GPR_LOAD r25, PPC_CONTEXT_OFFSET_GPR25(r4)
- PPC_GPR_LOAD r26, PPC_CONTEXT_OFFSET_GPR26(r4)
- PPC_GPR_LOAD r27, PPC_CONTEXT_OFFSET_GPR27(r4)
+ PPC_GPR_LOAD r24, PPC_CONTEXT_OFFSET_GPR24(r5)
+ PPC_GPR_LOAD r25, PPC_CONTEXT_OFFSET_GPR25(r5)
+ PPC_GPR_LOAD r26, PPC_CONTEXT_OFFSET_GPR26(r5)
+ PPC_GPR_LOAD r27, PPC_CONTEXT_OFFSET_GPR27(r5)
- PPC_GPR_LOAD r28, PPC_CONTEXT_OFFSET_GPR28(r4)
- PPC_GPR_LOAD r29, PPC_CONTEXT_OFFSET_GPR29(r4)
- PPC_GPR_LOAD r30, PPC_CONTEXT_OFFSET_GPR30(r4)
- PPC_GPR_LOAD r31, PPC_CONTEXT_OFFSET_GPR31(r4)
+ PPC_GPR_LOAD r28, PPC_CONTEXT_OFFSET_GPR28(r5)
+ PPC_GPR_LOAD r29, PPC_CONTEXT_OFFSET_GPR29(r5)
+ PPC_GPR_LOAD r30, PPC_CONTEXT_OFFSET_GPR30(r5)
+ PPC_GPR_LOAD r31, PPC_CONTEXT_OFFSET_GPR31(r5)
- lwz r2, PPC_CONTEXT_OFFSET_GPR2(r4)
+ lwz r2, PPC_CONTEXT_OFFSET_GPR2(r5)
- mtcr r7
- mtlr r6
- mtmsr r5
+ mtcr r8
+ mtlr r7
+ mtmsr r6
#ifdef BSP_USE_SYNC_IN_CONTEXT_SWITCH
isync
@@ -399,10 +407,42 @@ restore_context:
PUBLIC_PROC (_CPU_Context_restore)
PROC (_CPU_Context_restore):
- clrrwi r4, r3, 5
+ clrrwi r5, r3, 5
#ifdef __ALTIVEC__
li r3, 0
#endif
b restore_context
+#ifdef RTEMS_SMP
+check_thread_dispatch_necessary:
+ GET_SELF_CPU_CONTROL r6
+ /* Check if a thread dispatch is necessary */
+ lbz r7, PER_CPU_DISPATCH_NEEDED(r6)
+ cmpwi r7, 0
+ /* We have a new heir */
+ /* Clear the thread dispatch necessary flag */
+ li r7, 0
+ stb r7, PER_CPU_DISPATCH_NEEDED(r6)
+ msync
+ /* Read the executing and heir */
+ lwz r7, PER_CPU_OFFSET_EXECUTING(r6)
+ lwz r8, PER_CPU_OFFSET_HEIR(r6)
+ /* Calculate the heir context pointer */
+ sub r7, r4, r7
+ add r4, r8, r7
+ clrrwi r5, r4, 5
+ /* Update the executing */
+ stw r8, PER_CPU_OFFSET_EXECUTING(r6)
+ b check_is_executing
+#endif
diff --git a/cpukit/score/cpu/arm/arm_exc_interrupt.S b/cpukit/score/cpu/arm/arm_exc_interrupt.S
index c80a404..e8026c8 100644
--- a/cpukit/score/cpu/arm/arm_exc_interrupt.S
+++ b/cpukit/score/cpu/arm/arm_exc_interrupt.S
@@ -31,7 +31,6 @@
#endif
-#include <rtems/score/percpu.h>
#ifdef ARM_MULTILIB_ARCH_V4
@@ -49,17 +48,6 @@
#define CONTEXT_LIST {r0, r1, r2, r3, EXCHANGE_LR, EXCHANGE_SPSR, SELF_CPU_CONTROL, r12}
#define CONTEXT_SIZE 32
-.macro GET_SELF_CPU_CONTROL REG, TMP
- ldr \REG, =_Per_CPU_Information
-#ifdef RTEMS_SMP
- /* Use ARMv7 Multiprocessor Affinity Register (MPIDR) */
- mrc p15, 0, \TMP, c0, c0, 5
- and \TMP, \TMP, #0xff
- add \REG, \REG, \TMP, asl #PER_CPU_CONTROL_SIZE_LOG2
-#endif
-.endm
.arm
.globl _ARMV4_Exception_interrupt
_ARMV4_Exception_interrupt:
diff --git a/cpukit/score/cpu/arm/cpu_asm.S b/cpukit/score/cpu/arm/cpu_asm.S
index 7502923..306dfbf 100644
--- a/cpukit/score/cpu/arm/cpu_asm.S
+++ b/cpukit/score/cpu/arm/cpu_asm.S
@@ -30,7 +30,6 @@
#endif
@@ -73,21 +72,25 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
mov r3, #0
strb r3, [r0, #ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET]
-1:
- ldrb r3, [r1, #ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET]
- cmp r3, #0
- bne 1b
+.L_check_is_executing:
+ add r3, r1, #ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET
+ ldrexb r4, [r3]
+ cmp r4, #0
+ bne .L_check_thread_dispatch_necessary
+ mov r4, #1
+ strexb r5, r4, [r3]
+ cmp r5, #0
dmb
- mov r3, #1
- strb r3, [r1, #ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET]
#endif
/* Start restoring context */
.L_restore:
-#ifdef ARM_MULTILIB_HAS_LOAD_STORE_EXCLUSIVE
+#if !defined(RTEMS_SMP) && defined(ARM_MULTILIB_HAS_LOAD_STORE_EXCLUSIVE)
clrex
#endif
@@ -120,4 +123,35 @@ DEFINE_FUNCTION_ARM(_CPU_Context_restore)
mov r1, r0
b .L_restore
+#ifdef RTEMS_SMP
+.L_check_thread_dispatch_necessary:
+ GET_SELF_CPU_CONTROL r2, r3
+ ldrb r4, [r2, #PER_CPU_DISPATCH_NEEDED]
+ cmp r4, #0
+ beq .L_check_is_executing
+ mov r4, #0
+ strb r4, [r2, #PER_CPU_DISPATCH_NEEDED]
+ dmb
+ ldr r4, [r2, #PER_CPU_OFFSET_EXECUTING]
+ ldr r5, [r2, #PER_CPU_OFFSET_HEIR]
+ sub r4, r1, r4
+ add r1, r5, r4
+ str r5, [r2, #PER_CPU_OFFSET_EXECUTING]
+ b .L_check_is_executing
+#endif
#endif /* ARM_MULTILIB_ARCH_V4 */
diff --git a/cpukit/score/cpu/arm/rtems/asm.h b/cpukit/score/cpu/arm/rtems/asm.h
index 6539a38..d22514d 100644
--- a/cpukit/score/cpu/arm/rtems/asm.h
+++ b/cpukit/score/cpu/arm/rtems/asm.h
@@ -41,8 +41,7 @@
#ifndef ASM
#define ASM
#endif
-#include <rtems/score/cpuopts.h>
-#include <rtems/score/arm.h>
* @defgroup ScoreCPUARMASM ARM Assembler Support
@@ -188,6 +187,17 @@
#endif /* __thumb__ */
.endm
+.macro GET_SELF_CPU_CONTROL REG, TMP
+ ldr \REG, =_Per_CPU_Information
+#ifdef RTEMS_SMP
+ /* Use ARMv7 Multiprocessor Affinity Register (MPIDR) */
+ mrc p15, 0, \TMP, c0, c0, 5
+ and \TMP, \TMP, #0xff
+ add \REG, \REG, \TMP, asl #PER_CPU_CONTROL_SIZE_LOG2
+#endif
+.endm
#endif /* _RTEMS_ASM_H */
diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
index 9570fb6..9699033 100644
--- a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
@@ -578,11 +578,40 @@ typedef struct {
#ifdef RTEMS_SMP
* @brief On SMP configurations the thread context must contain a boolean
- * indicator if this context is executing on a processor.
+ * indicator to signal if this context is executing on a processor.
* This field must be updated during a context switch. The context switch
* to the heir must wait until the heir context indicates that it is no
- * longer executing on a processor.
+ * longer executing on a processor. The context switch must also check if
+ * a thread dispatch is necessary to honor updates of the heir thread for
+ * this processor. This indicator must be updated using an atomic test and
+ * set operation to ensure that at most one processor uses the heir
+ * context at the same time.
+ * @code
+ * void _CPU_Context_switch(
+ * Context_Control *executing,
+ * Context_Control *heir
+ * save(executing);
+ * executing->is_executing = false;
+ * memory_barrier();
+ * if (test_and_set(&heir->is_executing)) {
+ * do {
+ * Per_CPU_Control *cpu_self = _Per_CPU_Get_snapshot();
+ * if (cpu_self->dispatch_necessary) {
+ * heir = _Thread_Get_heir_and_make_it_executing(cpu_self);
+ * } while (test_and_set(&heir->is_executing));
+ * restore(heir);
+ * @endcode
volatile bool is_executing;
#endif
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index 3cad329..13f50ad 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -303,7 +303,7 @@ typedef struct {
PPC_GPR_TYPE gpr31;
uint32_t gpr2;
#ifdef RTEMS_SMP
- volatile bool is_executing;
+ volatile uint32_t is_executing;
#endif
#ifdef __ALTIVEC__
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index c010005..39b7825 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
@@ -475,7 +475,7 @@ typedef struct {
uint32_t isr_dispatch_disable;
#endif
} Context_Control;
1.7.7
