[PATCH] score: PR2183: Fix context switch on SMP
Wed Jul 2 15:35:36 UTC 2014
So far our testing shows this addresses the scenario
we were seeing. More testing has to occur on our side
because we need to clean up the code and see if we
added any logic that is now unneeded.
But ignoring any odd style comments, this seems to
fix the issue on the SPARC.
--joel
On 7/1/2014 9:18 AM, Sebastian Huber wrote:
> Fix context switch on SMP for ARM, PowerPC and SPARC.
> Atomically test and set the is executing indicator of the heir context
> to ensure that at most one processor uses the heir context.  Break the
> busy wait loop also due to heir updates.
>  c/src/lib/libbsp/sparc/shared/irq_asm.S           |   55 +++++++--
>  c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S |  140 +++++++++++++--------
>  cpukit/score/cpu/arm/arm_exc_interrupt.S          |   12 --
>  cpukit/score/cpu/arm/cpu_asm.S                    |   54 +++++++--
>  cpukit/score/cpu/arm/rtems/asm.h                  |   14 ++-
>  cpukit/score/cpu/no_cpu/rtems/score/cpu.h         |   33 +++++-
>  cpukit/score/cpu/powerpc/rtems/score/cpu.h        |    2 +-
>  cpukit/score/cpu/sparc/rtems/score/cpu.h          |    2 +-
>  8 files changed, 226 insertions(+), 86 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/shared/irq_asm.S b/c/src/lib/libbsp/sparc/shared/irq_asm.S
> index bf2dca9..7ba06bb 100644
> --- a/c/src/lib/libbsp/sparc/shared/irq_asm.S
> +++ b/c/src/lib/libbsp/sparc/shared/irq_asm.S
> @@ -165,17 +165,18 @@ done_flushing:
>  #if defined(RTEMS_SMP)
>          ! The executing context no longer executes on this processor
> -        stb     %g0, [%o0 + SPARC_CONTEXT_CONTROL_IS_EXECUTING_OFFSET]
> +        st      %g0, [%o0 + SPARC_CONTEXT_CONTROL_IS_EXECUTING_OFFSET]
> -        ! Wait for heir context to stop execution
> -1:
> -        ldub    [%o1 + SPARC_CONTEXT_CONTROL_IS_EXECUTING_OFFSET], %g1
> +        ! Try to update the is executing indicator of the heir context
> +        mov     1, %g1
> +try_update_is_executing:
> +        swap    [%o1 + SPARC_CONTEXT_CONTROL_IS_EXECUTING_OFFSET], %g1
>          cmp     %g1, 0
> -        bne     1b
> -         mov    1, %g1
> +        bne     check_is_executing
> -        ! The heir context executes now on this processor
> -        stb     %g1, [%o1 + SPARC_CONTEXT_CONTROL_IS_EXECUTING_OFFSET]
> +        ! The next load is in a delay slot, which is all right
>  #endif
>          ld      [%o1 + G5_OFFSET], %g5        ! restore the global registers
> @@ -203,6 +204,44 @@ done_flushing:
>          jmp     %o7 + 8                       ! return
>          nop                                   ! delay slot
> +#if defined(RTEMS_SMP)
> +check_is_executing:
> +        ! Check the is executing indicator of the heir context
> +        ld      [%o1 + SPARC_CONTEXT_CONTROL_IS_EXECUTING_OFFSET], %g1
> +        cmp     %g1, 0
> +        beq     try_update_is_executing
> +         mov    1, %g1
> +        ! Check if a thread dispatch is necessary
> +        ldub    [%g6 + PER_CPU_DISPATCH_NEEDED], %g1
> +        cmp     %g1, 0
> +        beq     check_is_executing
> +         nop
> +        ! We have a new heir
> +        ! Clear the thread dispatch necessary flag
> +        stub    %g0, [%g6 + PER_CPU_DISPATCH_NEEDED]
> +        ! Here we assume a strong memory order, otherwise a memory barrier must
> +        ! be inserted here
> +        ! Read the executing and heir
> +        ld      [%g6 + PER_CPU_OFFSET_EXECUTING], %g1
> +        ld      [%g6 + PER_CPU_OFFSET_HEIR], %g2
> +        ! Calculate the heir context pointer
> +        sub     %o1, %g1, %g1
> +        add     %g1, %g2, %o1
> +        ! Update the executing
> +        st      %g2, [%g6 + PER_CPU_OFFSET_EXECUTING]
> +        ba      try_update_is_executing
> +         mov    1, %g1
> +#endif
>   *  void _CPU_Context_restore(
>   *    Context_Control *new_context
> diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S b/c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S
> index 6bde8bd..35ceccc 100644
> --- a/c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S
> +++ b/c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S
> @@ -23,7 +23,7 @@
>   *  COPYRIGHT (c) 1989-1997.
>   *  On-Line Applications Research Corporation (OAR).
> - *  Copyright (c) 2011-2013 embedded brains GmbH.
> + *  Copyright (c) 2011-2014 embedded brains GmbH.
>   *  The license and distribution terms for this file may in
>   *  the file LICENSE in this distribution or at
> @@ -32,7 +32,8 @@
>  #include <rtems/asm.h>
>  #include <rtems/powerpc/powerpc.h>
> -#include <rtems/score/cpu.h>
> +#include <rtems/score/percpu.h>
> +#include <libcpu/powerpc-utility.h>
>  #include <bspopts.h>
>  #if PPC_DEFAULT_CACHE_LINE_SIZE != 32
> @@ -257,33 +258,37 @@ PROC (_CPU_Context_switch):
>         /* Align to a cache line */
>         clrrwi  r3, r3, 5
> -       clrrwi  r4, r4, 5
> +       clrrwi  r5, r4, 5
>         DATA_CACHE_ZERO_AND_TOUCH(r10, PPC_CONTEXT_CACHE_LINE_0)
>         DATA_CACHE_ZERO_AND_TOUCH(r11, PPC_CONTEXT_CACHE_LINE_1)
>         /* Save context to r3 */
> -       mfmsr   r5
> -       mflr    r6
> -       mfcr    r7
> +       mfmsr   r6
> +       mflr    r7
> +       mfcr    r8
>          * We have to clear the reservation of the executing thread.  See also
>          * Book E section 6.1.6.2 "Atomic Update Primitives".  Recent GCC
> -        * versions use atomic operations in the C++ library for example.
> +        * versions use atomic operations in the C++ library for example.  On
> +        * SMP configurations the reservation is cleared later during the
> +        * context switch.
>  #if PPC_CONTEXT_OFFSET_GPR1 != PPC_CONTEXT_CACHE_LINE_0 \
>    || !BSP_DATA_CACHE_ENABLED \
>    || PPC_CACHE_ALIGNMENT != 32
>         li      r10, PPC_CONTEXT_OFFSET_GPR1
>  #endif
> +#ifndef RTEMS_SMP
>         stwcx.  r1, r3, r10
> +#endif
>         stw     r1, PPC_CONTEXT_OFFSET_GPR1(r3)
> -       stw     r5, PPC_CONTEXT_OFFSET_MSR(r3)
> -       stw     r6, PPC_CONTEXT_OFFSET_LR(r3)
> -       stw     r7, PPC_CONTEXT_OFFSET_CR(r3)
> +       stw     r6, PPC_CONTEXT_OFFSET_MSR(r3)
> +       stw     r7, PPC_CONTEXT_OFFSET_LR(r3)
> +       stw     r8, PPC_CONTEXT_OFFSET_CR(r3)
>         PPC_GPR_STORE   r14, PPC_CONTEXT_OFFSET_GPR14(r3)
>         PPC_GPR_STORE   r15, PPC_CONTEXT_OFFSET_GPR15(r3)
> @@ -329,66 +334,69 @@ PROC (_CPU_Context_switch):
>  #ifdef RTEMS_SMP
>         /* The executing context no longer executes on this processor */
>         msync
> -       li      r5, 0
> -       stb     r5, PPC_CONTEXT_OFFSET_IS_EXECUTING(r3)
> +       li      r6, 0
> +       stw     r6, PPC_CONTEXT_OFFSET_IS_EXECUTING(r3)
> -       /* Wait for heir context to stop execution */
> -1:
> -       lbz     r5, PPC_CONTEXT_OFFSET_IS_EXECUTING(r4)
> -       cmpwi   r5, 0
> -       bne     1b
> -       /* The heir context executes now on this processor */
> -       li      r5, 1
> -       stb     r5, PPC_CONTEXT_OFFSET_IS_EXECUTING(r4)
> +       /* Check the is executing indicator of the heir context */
> +       addi    r6, r5, PPC_CONTEXT_OFFSET_IS_EXECUTING
> +       lwarx   r7, r0, r6
> +       cmpwi   r7, 0
> +       bne     check_thread_dispatch_necessary
> +       /* Try to update the is executing indicator of the heir context */
> +       li      r7, 1
> +       stwcx.  r7, r0, r6
>         isync
>  #endif
> -       /* Restore context from r4 */
> +       /* Restore context from r5 */
>  restore_context:
>  #ifdef __ALTIVEC__
> -       mr      r14, r4
> +       mr      r14, r5
>         .extern _CPU_Context_switch_altivec
>         bl      _CPU_Context_switch_altivec
> -       mr      r4, r14
> +       mr      r5, r14
>  #endif
> -       lwz     r1, PPC_CONTEXT_OFFSET_GPR1(r4)
> -       lwz     r5, PPC_CONTEXT_OFFSET_MSR(r4)
> -       lwz     r6, PPC_CONTEXT_OFFSET_LR(r4)
> -       lwz     r7, PPC_CONTEXT_OFFSET_CR(r4)
> +       lwz     r1, PPC_CONTEXT_OFFSET_GPR1(r5)
> +       lwz     r6, PPC_CONTEXT_OFFSET_MSR(r5)
> +       lwz     r7, PPC_CONTEXT_OFFSET_LR(r5)
> +       lwz     r8, PPC_CONTEXT_OFFSET_CR(r5)
> -       PPC_GPR_LOAD    r14, PPC_CONTEXT_OFFSET_GPR14(r4)
> -       PPC_GPR_LOAD    r15, PPC_CONTEXT_OFFSET_GPR15(r4)
> +       PPC_GPR_LOAD    r14, PPC_CONTEXT_OFFSET_GPR14(r5)
> +       PPC_GPR_LOAD    r15, PPC_CONTEXT_OFFSET_GPR15(r5)
>         DATA_CACHE_TOUCH(r0, r1)
> -       PPC_GPR_LOAD    r16, PPC_CONTEXT_OFFSET_GPR16(r4)
> -       PPC_GPR_LOAD    r17, PPC_CONTEXT_OFFSET_GPR17(r4)
> -       PPC_GPR_LOAD    r18, PPC_CONTEXT_OFFSET_GPR18(r4)
> -       PPC_GPR_LOAD    r19, PPC_CONTEXT_OFFSET_GPR19(r4)
> +       PPC_GPR_LOAD    r16, PPC_CONTEXT_OFFSET_GPR16(r5)
> +       PPC_GPR_LOAD    r17, PPC_CONTEXT_OFFSET_GPR17(r5)
> +       PPC_GPR_LOAD    r18, PPC_CONTEXT_OFFSET_GPR18(r5)
> +       PPC_GPR_LOAD    r19, PPC_CONTEXT_OFFSET_GPR19(r5)
> -       PPC_GPR_LOAD    r20, PPC_CONTEXT_OFFSET_GPR20(r4)
> -       PPC_GPR_LOAD    r21, PPC_CONTEXT_OFFSET_GPR21(r4)
> -       PPC_GPR_LOAD    r22, PPC_CONTEXT_OFFSET_GPR22(r4)
> -       PPC_GPR_LOAD    r23, PPC_CONTEXT_OFFSET_GPR23(r4)
> +       PPC_GPR_LOAD    r20, PPC_CONTEXT_OFFSET_GPR20(r5)
> +       PPC_GPR_LOAD    r21, PPC_CONTEXT_OFFSET_GPR21(r5)
> +       PPC_GPR_LOAD    r22, PPC_CONTEXT_OFFSET_GPR22(r5)
> +       PPC_GPR_LOAD    r23, PPC_CONTEXT_OFFSET_GPR23(r5)
> -       PPC_GPR_LOAD    r24, PPC_CONTEXT_OFFSET_GPR24(r4)
> -       PPC_GPR_LOAD    r25, PPC_CONTEXT_OFFSET_GPR25(r4)
> -       PPC_GPR_LOAD    r26, PPC_CONTEXT_OFFSET_GPR26(r4)
> -       PPC_GPR_LOAD    r27, PPC_CONTEXT_OFFSET_GPR27(r4)
> +       PPC_GPR_LOAD    r24, PPC_CONTEXT_OFFSET_GPR24(r5)
> +       PPC_GPR_LOAD    r25, PPC_CONTEXT_OFFSET_GPR25(r5)
> +       PPC_GPR_LOAD    r26, PPC_CONTEXT_OFFSET_GPR26(r5)
> +       PPC_GPR_LOAD    r27, PPC_CONTEXT_OFFSET_GPR27(r5)
> -       PPC_GPR_LOAD    r28, PPC_CONTEXT_OFFSET_GPR28(r4)
> -       PPC_GPR_LOAD    r29, PPC_CONTEXT_OFFSET_GPR29(r4)
> -       PPC_GPR_LOAD    r30, PPC_CONTEXT_OFFSET_GPR30(r4)
> -       PPC_GPR_LOAD    r31, PPC_CONTEXT_OFFSET_GPR31(r4)
> +       PPC_GPR_LOAD    r28, PPC_CONTEXT_OFFSET_GPR28(r5)
> +       PPC_GPR_LOAD    r29, PPC_CONTEXT_OFFSET_GPR29(r5)
> +       PPC_GPR_LOAD    r30, PPC_CONTEXT_OFFSET_GPR30(r5)
> +       PPC_GPR_LOAD    r31, PPC_CONTEXT_OFFSET_GPR31(r5)
> -       lwz     r2, PPC_CONTEXT_OFFSET_GPR2(r4)
> +       lwz     r2, PPC_CONTEXT_OFFSET_GPR2(r5)
> -       mtcr    r7
> -       mtlr    r6
> -       mtmsr   r5
> +       mtcr    r8
> +       mtlr    r7
> +       mtmsr   r6
>  #ifdef BSP_USE_SYNC_IN_CONTEXT_SWITCH
>         isync
> @@ -399,10 +407,42 @@ restore_context:
>         PUBLIC_PROC (_CPU_Context_restore)
>  PROC (_CPU_Context_restore):
> -       clrrwi  r4, r3, 5
> +       clrrwi  r5, r3, 5
>  #ifdef __ALTIVEC__
>         li      r3, 0
>  #endif
>         b       restore_context
> +#ifdef RTEMS_SMP
> +check_thread_dispatch_necessary:
> +       GET_SELF_CPU_CONTROL    r6
> +       /* Check if a thread dispatch is necessary */
> +       lbz     r7, PER_CPU_DISPATCH_NEEDED(r6)
> +       cmpwi   r7, 0
> +       /* We have a new heir */
> +       /* Clear the thread dispatch necessary flag */
> +       li      r7, 0
> +       stb     r7, PER_CPU_DISPATCH_NEEDED(r6)
> +       msync
> +       /* Read the executing and heir */
> +       lwz     r7, PER_CPU_OFFSET_EXECUTING(r6)
> +       lwz     r8, PER_CPU_OFFSET_HEIR(r6)
> +       /* Calculate the heir context pointer */
> +       sub     r7, r4, r7
> +       add     r4, r8, r7
> +       clrrwi  r5, r4, 5
> +       /* Update the executing */
> +       stw     r8, PER_CPU_OFFSET_EXECUTING(r6)
> +       b       check_is_executing
> +#endif
> diff --git a/cpukit/score/cpu/arm/arm_exc_interrupt.S b/cpukit/score/cpu/arm/arm_exc_interrupt.S
> index c80a404..e8026c8 100644
> --- a/cpukit/score/cpu/arm/arm_exc_interrupt.S
> +++ b/cpukit/score/cpu/arm/arm_exc_interrupt.S
> @@ -31,7 +31,6 @@
>  #endif
> -#include <rtems/score/percpu.h>
>  #ifdef ARM_MULTILIB_ARCH_V4
> @@ -49,17 +48,6 @@
>  #define CONTEXT_LIST {r0, r1, r2, r3, EXCHANGE_LR, EXCHANGE_SPSR, SELF_CPU_CONTROL, r12}
>  #define CONTEXT_SIZE 32
> -.macro GET_SELF_CPU_CONTROL REG, TMP
> -       ldr     \REG, =_Per_CPU_Information
> -#ifdef RTEMS_SMP
> -       /* Use ARMv7 Multiprocessor Affinity Register (MPIDR) */
> -       mrc     p15, 0, \TMP, c0, c0, 5
> -       and     \TMP, \TMP, #0xff
> -       add     \REG, \REG, \TMP, asl #PER_CPU_CONTROL_SIZE_LOG2
> -#endif
> -.endm
>  .arm
>  .globl _ARMV4_Exception_interrupt
>  _ARMV4_Exception_interrupt:
> diff --git a/cpukit/score/cpu/arm/cpu_asm.S b/cpukit/score/cpu/arm/cpu_asm.S
> index 7502923..306dfbf 100644
> --- a/cpukit/score/cpu/arm/cpu_asm.S
> +++ b/cpukit/score/cpu/arm/cpu_asm.S
> @@ -30,7 +30,6 @@
>  #endif
> @@ -73,21 +72,25 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
>         mov     r3, #0
>         strb    r3, [r0, #ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET]
> -1:
> -       ldrb    r3, [r1, #ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET]
> -       cmp     r3, #0
> -       bne     1b
> +.L_check_is_executing:
> +       add     r3, r1, #ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET
> +       ldrexb  r4, [r3]
> +       cmp     r4, #0
> +       bne     .L_check_thread_dispatch_necessary
> +       mov     r4, #1
> +       strexb  r5, r4, [r3]
> +       cmp     r5, #0
>         dmb
> -       mov     r3, #1
> -       strb    r3, [r1, #ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET]
>  #endif
>  /* Start restoring context */
>  .L_restore:
> -#ifdef ARM_MULTILIB_HAS_LOAD_STORE_EXCLUSIVE
> +#if !defined(RTEMS_SMP) && defined(ARM_MULTILIB_HAS_LOAD_STORE_EXCLUSIVE)
>         clrex
>  #endif
> @@ -120,4 +123,35 @@ DEFINE_FUNCTION_ARM(_CPU_Context_restore)
>          mov     r1, r0
>          b       .L_restore
> +#ifdef RTEMS_SMP
> +.L_check_thread_dispatch_necessary:
> +       GET_SELF_CPU_CONTROL    r2, r3
> +       ldrb    r4, [r2, #PER_CPU_DISPATCH_NEEDED]
> +       cmp     r4, #0
> +       beq     .L_check_is_executing
> +       mov     r4, #0
> +       strb    r4, [r2, #PER_CPU_DISPATCH_NEEDED]
> +       dmb
> +       ldr     r4, [r2, #PER_CPU_OFFSET_EXECUTING]
> +       ldr     r5, [r2, #PER_CPU_OFFSET_HEIR]
> +       sub     r4, r1, r4
> +       add     r1, r5, r4
> +       str     r5, [r2, #PER_CPU_OFFSET_EXECUTING]
> +       b       .L_check_is_executing
> +#endif
>  #endif /* ARM_MULTILIB_ARCH_V4 */
> diff --git a/cpukit/score/cpu/arm/rtems/asm.h b/cpukit/score/cpu/arm/rtems/asm.h
> index 6539a38..d22514d 100644
> --- a/cpukit/score/cpu/arm/rtems/asm.h
> +++ b/cpukit/score/cpu/arm/rtems/asm.h
> @@ -41,8 +41,7 @@
>  #ifndef ASM
>  #define ASM
>  #endif
> -#include <rtems/score/cpuopts.h>
> -#include <rtems/score/arm.h>
>   * @defgroup ScoreCPUARMASM ARM Assembler Support
> @@ -188,6 +187,17 @@
>  #endif /* __thumb__ */
>  .endm
> +.macro GET_SELF_CPU_CONTROL REG, TMP
> +       ldr     \REG, =_Per_CPU_Information
> +#ifdef RTEMS_SMP
> +       /* Use ARMv7 Multiprocessor Affinity Register (MPIDR) */
> +       mrc     p15, 0, \TMP, c0, c0, 5
> +       and     \TMP, \TMP, #0xff
> +       add     \REG, \REG, \TMP, asl #PER_CPU_CONTROL_SIZE_LOG2
> +#endif
> +.endm
>  #endif /* _RTEMS_ASM_H */
> diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
> index 9570fb6..9699033 100644
> --- a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
> @@ -578,11 +578,40 @@ typedef struct {
>  #ifdef RTEMS_SMP
>       * @brief On SMP configurations the thread context must contain a boolean
> -     * indicator if this context is executing on a processor.
> +     * indicator to signal if this context is executing on a processor.
>       * This field must be updated during a context switch.  The context switch
>       * to the heir must wait until the heir context indicates that it is no
> -     * longer executing on a processor.
> +     * longer executing on a processor.  The context switch must also check if
> +     * a thread dispatch is necessary to honor updates of the heir thread for
> +     * this processor.  This indicator must be updated using an atomic test and
> +     * set operation to ensure that at most one processor uses the heir
> +     * context at the same time.
> +     * @code
> +     * void _CPU_Context_switch(
> +     *   Context_Control *executing,
> +     *   Context_Control *heir
> +     *   save(executing);
> +     *   executing->is_executing = false;
> +     *   memory_barrier();
> +     *   if (test_and_set(&heir->is_executing)) {
> +     *     do {
> +     *       Per_CPU_Control *cpu_self = _Per_CPU_Get_snapshot();
> +     *       if (cpu_self->dispatch_necessary) {
> +     *         heir = _Thread_Get_heir_and_make_it_executing(cpu_self);
> +     *     } while (test_and_set(&heir->is_executing));
> +     *   restore(heir);
> +     * @endcode
>      volatile bool is_executing;
>  #endif
> diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
> index 3cad329..13f50ad 100644
> --- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
> @@ -303,7 +303,7 @@ typedef struct {
>    PPC_GPR_TYPE gpr31;
>    uint32_t gpr2;
>    #ifdef RTEMS_SMP
> -    volatile bool is_executing;
> +    volatile uint32_t is_executing;
>    #endif
>    #ifdef __ALTIVEC__
> diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> index c010005..39b7825 100644
> --- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> @@ -475,7 +475,7 @@ typedef struct {
>    uint32_t   isr_dispatch_disable;
>  #endif
>  } Context_Control;
> 1.7.7
> devel mailing list
> devel at rtems.org
