[PATCH 4/5 v2] SPARC: Fatal_halt use source and exit codes
Daniel Hellstrom daniel at gaisler.com
Thu Jul 3 07:29:29 UTC 2014
PATCHv2: BSP_fatal_halt renamed to _BSP_Fatal_halt
The Fatal_halt handler now have two options, either halt
as before or enter system error state to return to
debugger or simulator. The exit-code is now also
propagated to the debugger which is very useful for
testing.
The CPU_Fatal_halt handler was split up into two, since
the only the LEON3 support the CPU power down.
The LEON3 halt now uses the power-down instruction to save
CPU power. This doesn't stop a potential watch-dog timer
from expiring.
 c/src/lib/libbsp/sparc/erc32/Makefile.am           |    1 +
 c/src/lib/libbsp/sparc/erc32/configure.ac          |    5 +++
 c/src/lib/libbsp/sparc/leon2/Makefile.am           |    1 +
 c/src/lib/libbsp/sparc/leon2/configure.ac          |    5 +++
 c/src/lib/libbsp/sparc/leon3/Makefile.am           |    1 +
 c/src/lib/libbsp/sparc/leon3/configure.ac          |    5 +++
 .../libbsp/sparc/leon3/startup/bsp_fatal_halt.c    |   36 ++++++++++++++++++
 .../libbsp/sparc/shared/startup/bsp_fatal_halt.c   |   38 ++++++++++++++++++++
 cpukit/score/cpu/sparc/rtems/score/cpu.h           |   12 ++----
 9 files changed, 96 insertions(+), 8 deletions(-)
 create mode 100644 c/src/lib/libbsp/sparc/leon3/startup/bsp_fatal_halt.c
 create mode 100644 c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_halt.c
diff --git a/c/src/lib/libbsp/sparc/erc32/Makefile.am b/c/src/lib/libbsp/sparc/erc32/Makefile.am
index b9f1c53..00e398b 100644
--- a/c/src/lib/libbsp/sparc/erc32/Makefile.am
+++ b/c/src/lib/libbsp/sparc/erc32/Makefile.am
@@ -46,6 +46,7 @@ libbsp_a_SOURCES += startup/bspidle.c
 libbsp_a_SOURCES += startup/bspdelay.c
 libbsp_a_SOURCES += ../../sparc/shared/startup/early_malloc.c
 libbsp_a_SOURCES += ../../sparc/shared/startup/bsp_fatal_exit.c
+libbsp_a_SOURCES += ../../sparc/shared/startup/bsp_fatal_halt.c
 # ISR Handler
 libbsp_a_SOURCES += ../../sparc/shared/cpu.c
 libbsp_a_SOURCES += ../../sparc/shared/irq_asm.S
diff --git a/c/src/lib/libbsp/sparc/erc32/configure.ac b/c/src/lib/libbsp/sparc/erc32/configure.ac
index 4cbfb7e..bb5174a 100644
--- a/c/src/lib/libbsp/sparc/erc32/configure.ac
+++ b/c/src/lib/libbsp/sparc/erc32/configure.ac
@@ -43,6 +43,11 @@ RTEMS_BSPOPTS_HELP([ENABLE_SIS_QUIRKS],
  BSP will be enabled.  In particular, SIS requires special
  initialization not used on real ERC32 hardware.])
+RTEMS_BSPOPTS_SET([BSP_HALT_AT_FATAL_EXIT],[*],[])
+RTEMS_BSPOPTS_HELP([BSP_HALT_AT_FATAL_EXIT],
+[If defined, CPU is spinning on fatal exit. Otherwise generate system
+ error which will hand over to debugger, simulator, etc.])
 RTEMS_BSP_CLEANUP_OPTIONS(0,1,1)
 # Explicitly list all Makefiles here
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index 3f8edf4..ac6f327 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -61,6 +61,7 @@ libbsp_a_SOURCES += ../../shared/bspinit.c
 # ISR Handler
diff --git a/c/src/lib/libbsp/sparc/leon2/configure.ac b/c/src/lib/libbsp/sparc/leon2/configure.ac
index 610a049..1975a10 100644
--- a/c/src/lib/libbsp/sparc/leon2/configure.ac
+++ b/c/src/lib/libbsp/sparc/leon2/configure.ac
@@ -36,6 +36,11 @@ RTEMS_BSPOPTS_HELP([SIMSPARC_FAST_IDLE],
  time spent in the idle task is minimized.  This significantly reduces
  the wall time required to execute the RTEMS test suites.])
 RTEMS_BSP_CLEANUP_OPTIONS(0, 1, 1)
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index 54c9f22..d1f07a7 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -42,6 +42,7 @@ libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
 libbsp_a_SOURCES += startup/bspreset.c
 libbsp_a_SOURCES += startup/cpucounter.c
+libbsp_a_SOURCES += startup/bsp_fatal_halt.c
 # ISR Handler
diff --git a/c/src/lib/libbsp/sparc/leon3/configure.ac b/c/src/lib/libbsp/sparc/leon3/configure.ac
index 3fe1e48..206a662 100644
--- a/c/src/lib/libbsp/sparc/leon3/configure.ac
+++ b/c/src/lib/libbsp/sparc/leon3/configure.ac
@@ -38,6 +38,11 @@ RTEMS_BSPOPTS_HELP([BSP_LEON3_SMP],
 [Always defined when on a LEON3 to enable the LEON3 support for
  determining the CPU core number in an SMP configuration.])
+[If defined, CPU is powered down on fatal exit. Otherwise generate system
 RTEMS_BSP_LINKCMDS
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/bsp_fatal_halt.c b/c/src/lib/libbsp/sparc/leon3/startup/bsp_fatal_halt.c
new file mode 100644
index 0000000..4350faf
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/startup/bsp_fatal_halt.c
@@ -0,0 +1,36 @@
+ * @file
+ * @ingroup sparc_leon3
+ * @brief LEON3 BSP Fatal_halt handler.
+ *  COPYRIGHT (c) 2014.
+ *  Aeroflex Gaisler AB.
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#include <leon.h>
+#include <rtems/score/sparc.h>
+#ifdef BSP_HALT_AT_FATAL_EXIT
+/* Power down LEON CPU on fatal error exit */
+void _BSP_Fatal_halt(uint32_t source, uint32_t error)
+  sparc_disable_interrupts();
+  leon3_power_down_loop();
+#else
+/* return to debugger, simulator, hypervisor or similar by exiting
+ * with an error code. g1=1, g2=FATAL_SOURCE, G3=error-code.
+  sparc_syscall_exit(source, error);
+#endif
diff --git a/c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_halt.c b/c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_halt.c
index 0000000..349db20
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_halt.c
@@ -0,0 +1,38 @@
+ * @file
+ * @ingroup sparc_bsp
+ * @brief ERC32/LEON2 BSP Fatal_halt handler.
+/* Spin CPU on fatal error exit */
+  uint32_t level = sparc_disable_interrupts();
+  __asm__ volatile ( "mov  %0, %%g1 " : "=r" (level) : "0" (level) );
+  while (1) ; /* loop forever */
+#else
+#endif
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index 58c843a..0bb1bf5 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
@@ -1075,19 +1075,15 @@ void _CPU_Context_Initialize(
 /* Fatal Error manager macros */
+extern void _BSP_Fatal_halt(uint32_t source, uint32_t error)
+  RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
  * This routine copies _error into a known place -- typically a stack
  * location or a register, optionally disables interrupts, and
  * halts/stops the CPU.
-#define _CPU_Fatal_halt( _source, _error ) \
-  do { \
-    uint32_t   level; \
-    level = sparc_disable_interrupts(); \
-    __asm__ volatile ( "mov  %0, %%g1 " : "=r" (level) : "0" (level) ); \
-    while (1); /* loop forever */ \
-  } while (0)
+#define _CPU_Fatal_halt( _source, _error ) _BSP_Fatal_halt( _source, _error )
 /* end of Fatal Error manager macros */
1.7.0.4
