[PATCH 4/5 v2] SPARC: Fatal_halt use source and exit codes
Thu Jul 3 14:55:48 UTC 2014
I am wondering if I don't have a vision for what this
series of patches is trying to accomplish in whole.
And I am hung up on not wanting BSP references in
score. So I would like an elegant solution.
How does tweaking the bsp_reset() method not
address all of this? It is invoked along the _Terminate()
path already.
As an aside, should the _Internal_errors_What_happened
structure be filled in earlier in _Terminate? How about
just after disabling interrupts?
On 7/3/2014 2:29 AM, Daniel Hellstrom wrote:
> PATCHv2: BSP_fatal_halt renamed to _BSP_Fatal_halt
> The Fatal_halt handler now have two options, either halt
> as before or enter system error state to return to
> debugger or simulator. The exit-code is now also
> propagated to the debugger which is very useful for
> testing.
> The CPU_Fatal_halt handler was split up into two, since
> the only the LEON3 support the CPU power down.
> The LEON3 halt now uses the power-down instruction to save
> CPU power. This doesn't stop a potential watch-dog timer
> from expiring.
>  c/src/lib/libbsp/sparc/erc32/Makefile.am           |    1 +
>  c/src/lib/libbsp/sparc/erc32/configure.ac          |    5 +++
>  c/src/lib/libbsp/sparc/leon2/Makefile.am           |    1 +
>  c/src/lib/libbsp/sparc/leon2/configure.ac          |    5 +++
>  c/src/lib/libbsp/sparc/leon3/Makefile.am           |    1 +
>  c/src/lib/libbsp/sparc/leon3/configure.ac          |    5 +++
>  .../libbsp/sparc/leon3/startup/bsp_fatal_halt.c    |   36 ++++++++++++++++++
>  .../libbsp/sparc/shared/startup/bsp_fatal_halt.c   |   38 ++++++++++++++++++++
>  cpukit/score/cpu/sparc/rtems/score/cpu.h           |   12 ++----
>  9 files changed, 96 insertions(+), 8 deletions(-)
>  create mode 100644 c/src/lib/libbsp/sparc/leon3/startup/bsp_fatal_halt.c
>  create mode 100644 c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_halt.c
> diff --git a/c/src/lib/libbsp/sparc/erc32/Makefile.am b/c/src/lib/libbsp/sparc/erc32/Makefile.am
> index b9f1c53..00e398b 100644
> --- a/c/src/lib/libbsp/sparc/erc32/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/erc32/Makefile.am
> @@ -46,6 +46,7 @@ libbsp_a_SOURCES += startup/bspidle.c
>  libbsp_a_SOURCES += startup/bspdelay.c
>  libbsp_a_SOURCES += ../../sparc/shared/startup/early_malloc.c
>  libbsp_a_SOURCES += ../../sparc/shared/startup/bsp_fatal_exit.c
> +libbsp_a_SOURCES += ../../sparc/shared/startup/bsp_fatal_halt.c
>  # ISR Handler
>  libbsp_a_SOURCES += ../../sparc/shared/cpu.c
>  libbsp_a_SOURCES += ../../sparc/shared/irq_asm.S
> diff --git a/c/src/lib/libbsp/sparc/erc32/configure.ac b/c/src/lib/libbsp/sparc/erc32/configure.ac
> index 4cbfb7e..bb5174a 100644
> --- a/c/src/lib/libbsp/sparc/erc32/configure.ac
> +++ b/c/src/lib/libbsp/sparc/erc32/configure.ac
> @@ -43,6 +43,11 @@ RTEMS_BSPOPTS_HELP([ENABLE_SIS_QUIRKS],
>   BSP will be enabled.  In particular, SIS requires special
>   initialization not used on real ERC32 hardware.])
> +RTEMS_BSPOPTS_SET([BSP_HALT_AT_FATAL_EXIT],[*],[])
> +RTEMS_BSPOPTS_HELP([BSP_HALT_AT_FATAL_EXIT],
> +[If defined, CPU is spinning on fatal exit. Otherwise generate system
> + error which will hand over to debugger, simulator, etc.])
Why would anyone want the CPU to go into a spin?
>  RTEMS_BSP_CLEANUP_OPTIONS(0,1,1)
>  # Explicitly list all Makefiles here
> diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
> index 3f8edf4..ac6f327 100644
> --- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
> @@ -61,6 +61,7 @@ libbsp_a_SOURCES += ../../shared/bspinit.c
>  # ISR Handler
> diff --git a/c/src/lib/libbsp/sparc/leon2/configure.ac b/c/src/lib/libbsp/sparc/leon2/configure.ac
> index 610a049..1975a10 100644
> --- a/c/src/lib/libbsp/sparc/leon2/configure.ac
> +++ b/c/src/lib/libbsp/sparc/leon2/configure.ac
> @@ -36,6 +36,11 @@ RTEMS_BSPOPTS_HELP([SIMSPARC_FAST_IDLE],
>   time spent in the idle task is minimized.  This significantly reduces
>   the wall time required to execute the RTEMS test suites.])
>  RTEMS_BSP_CLEANUP_OPTIONS(0, 1, 1)
> diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> index 54c9f22..d1f07a7 100644
> --- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> @@ -42,6 +42,7 @@ libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
>  libbsp_a_SOURCES += startup/bspreset.c
>  libbsp_a_SOURCES += startup/cpucounter.c
> +libbsp_a_SOURCES += startup/bsp_fatal_halt.c
>  # ISR Handler
> diff --git a/c/src/lib/libbsp/sparc/leon3/configure.ac b/c/src/lib/libbsp/sparc/leon3/configure.ac
> index 3fe1e48..206a662 100644
> --- a/c/src/lib/libbsp/sparc/leon3/configure.ac
> +++ b/c/src/lib/libbsp/sparc/leon3/configure.ac
> @@ -38,6 +38,11 @@ RTEMS_BSPOPTS_HELP([BSP_LEON3_SMP],
>  [Always defined when on a LEON3 to enable the LEON3 support for
>   determining the CPU core number in an SMP configuration.])
> +[If defined, CPU is powered down on fatal exit. Otherwise generate system
>  RTEMS_BSP_LINKCMDS
> diff --git a/c/src/lib/libbsp/sparc/leon3/startup/bsp_fatal_halt.c b/c/src/lib/libbsp/sparc/leon3/startup/bsp_fatal_halt.c
> new file mode 100644
> index 0000000..4350faf
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/leon3/startup/bsp_fatal_halt.c
> @@ -0,0 +1,36 @@
> + * @file
> + * @ingroup sparc_leon3
> + * @brief LEON3 BSP Fatal_halt handler.
> + *  COPYRIGHT (c) 2014.
> + *  Aeroflex Gaisler AB.
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.org/license/LICENSE.
> +#include <leon.h>
> +#include <rtems/score/sparc.h>
> +#ifdef BSP_HALT_AT_FATAL_EXIT
> +/* Power down LEON CPU on fatal error exit */
> +void _BSP_Fatal_halt(uint32_t source, uint32_t error)
> +  sparc_disable_interrupts();
> +  leon3_power_down_loop();
> +#else
> +/* return to debugger, simulator, hypervisor or similar by exiting
> + * with an error code. g1=1, g2=FATAL_SOURCE, G3=error-code.
> +  sparc_syscall_exit(source, error);
> +#endif
> diff --git a/c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_halt.c b/c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_halt.c
> index 0000000..349db20
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_halt.c
> @@ -0,0 +1,38 @@
> + * @file
> + * @ingroup sparc_bsp
> + * @brief ERC32/LEON2 BSP Fatal_halt handler.
> +/* Spin CPU on fatal error exit */
> +  uint32_t level = sparc_disable_interrupts();
> +  __asm__ volatile ( "mov  %0, %%g1 " : "=r" (level) : "0" (level) );
> +  while (1) ; /* loop forever */
> +#else
> +#endif
> diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> index 58c843a..0bb1bf5 100644
> --- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> @@ -1075,19 +1075,15 @@ void _CPU_Context_Initialize(
>  /* Fatal Error manager macros */
> +extern void _BSP_Fatal_halt(uint32_t source, uint32_t error)
> +  RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
I am really having trouble invoking a BSP specific routine
out of score/cpu. Can't you do this in the bsp_reset()
method?
If not, the leon3 is now a multilib so you can just have a
leon3 specific version of this macro.
>   * This routine copies _error into a known place -- typically a stack
>   * location or a register, optionally disables interrupts, and
>   * halts/stops the CPU.
> -#define _CPU_Fatal_halt( _source, _error ) \
> -  do { \
> -    uint32_t   level; \
> -    level = sparc_disable_interrupts(); \
> -    __asm__ volatile ( "mov  %0, %%g1 " : "=r" (level) : "0" (level) ); \
> -    while (1); /* loop forever */ \
> -  } while (0)
> +#define _CPU_Fatal_halt( _source, _error ) _BSP_Fatal_halt( _source, _error )
>  /* end of Fatal Error manager macros */
