[PATCH 3/5 v2] SPARC: add BSP specific error handler
Thu Jul 3 14:48:38 UTC 2014
I don't have a problem with this in principle but reviewing
the earlier patches and seeing similar names in other
BSPs makes me wonder if we can't get a better name.
Isn't this really just bsp_reset?
I don't see needing the symbol BSP_fatal_exit().
On 7/3/2014 2:29 AM, Daniel Hellstrom wrote:
> PATCHv2: BSP_fatal_exit defined in header
> Instead of calling the system call TA instruction directly it
> is better paractise to isolate the trap implementation to the
> system call functions.
> BSP_fatal_exit() is added.
>  c/src/lib/libbsp/sparc/erc32/Makefile.am           |    1 +
>  c/src/lib/libbsp/sparc/erc32/include/bsp.h         |    2 ++
>  c/src/lib/libbsp/sparc/leon2/Makefile.am           |    1 +
>  c/src/lib/libbsp/sparc/leon2/include/bsp.h         |    2 ++
>  c/src/lib/libbsp/sparc/leon3/Makefile.am           |    1 +
>  c/src/lib/libbsp/sparc/leon3/include/bsp.h         |    2 ++
>  c/src/lib/libbsp/sparc/shared/start/start.S        |    5 ++---
>  .../libbsp/sparc/shared/startup/bsp_fatal_exit.c   |   19 +++++++++++++++++++
>  8 files changed, 30 insertions(+), 3 deletions(-)
>  create mode 100644 c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_exit.c
> diff --git a/c/src/lib/libbsp/sparc/erc32/Makefile.am b/c/src/lib/libbsp/sparc/erc32/Makefile.am
> index d5de377..b9f1c53 100644
> --- a/c/src/lib/libbsp/sparc/erc32/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/erc32/Makefile.am
> @@ -45,6 +45,7 @@ libbsp_a_SOURCES += startup/boardinit.S
>  libbsp_a_SOURCES += startup/bspidle.c
>  libbsp_a_SOURCES += startup/bspdelay.c
>  libbsp_a_SOURCES += ../../sparc/shared/startup/early_malloc.c
> +libbsp_a_SOURCES += ../../sparc/shared/startup/bsp_fatal_exit.c
>  # ISR Handler
>  libbsp_a_SOURCES += ../../sparc/shared/cpu.c
>  libbsp_a_SOURCES += ../../sparc/shared/irq_asm.S
> diff --git a/c/src/lib/libbsp/sparc/erc32/include/bsp.h b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
> index fbe8988..b1cc83e 100644
> --- a/c/src/lib/libbsp/sparc/erc32/include/bsp.h
> +++ b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
> @@ -92,6 +92,8 @@ rtems_isr_entry set_vector(                     /* returns old vector */
>      int                 type                    /* RTEMS or RAW intr  */
> +void BSP_fatal_exit(uint32_t error);
>  void bsp_spurious_initialize( void );
>  /* Allocate 8-byte aligned non-freeable pre-malloc() memory. The function
> diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
> index e808b33..3f8edf4 100644
> --- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
> @@ -60,6 +60,7 @@ libbsp_a_SOURCES += startup/bspidle.c
>  libbsp_a_SOURCES += ../../shared/bspinit.c
>  # ISR Handler
> diff --git a/c/src/lib/libbsp/sparc/leon2/include/bsp.h b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
> index 63af19e..1943baf 100644
> --- a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
> +++ b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
> @@ -113,6 +113,8 @@ rtems_isr_entry set_vector(                     /* returns old vector */
> diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> index 5dd43c3..54c9f22 100644
> --- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> @@ -41,6 +41,7 @@ libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
>      ../../shared/bspinit.c ../../sparc/shared/startup/early_malloc.c
>  libbsp_a_SOURCES += startup/bspreset.c
>  libbsp_a_SOURCES += startup/cpucounter.c
>  # ISR Handler
> diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
> index ce4fe09..5f6f0a0 100644
> --- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
> +++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
> @@ -131,6 +131,8 @@ rtems_isr_entry set_vector(                     /* returns old vector */
> diff --git a/c/src/lib/libbsp/sparc/shared/start/start.S b/c/src/lib/libbsp/sparc/shared/start/start.S
> index e621c39..8f10000 100644
> --- a/c/src/lib/libbsp/sparc/shared/start/start.S
> +++ b/c/src/lib/libbsp/sparc/shared/start/start.S
> @@ -368,9 +368,8 @@ zerobss:
>  #if !defined(START_LEON3_ENABLE_SMP)
>          PUBLIC(bsp_reset)
>  SYM(bsp_reset):
> -	mov	1, %g1
> -        ta      0                       ! Halt if _main returns ...
> -        nop
> +        call    SYM(BSP_fatal_exit)
> +         clr     %o0
>  #endif
>  /* end of file */
> diff --git a/c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_exit.c b/c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_exit.c
> new file mode 100644
> index 0000000..c7ba6c2
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_exit.c
> @@ -0,0 +1,19 @@
> + * @file
> + * @ingroup sparc_bsp
> + * @brief ERC32/LEON2/LEON3 BSP specific exit handler.
> + *  COPYRIGHT (c) 2014.
> + *  Aeroflex Gaisler AB.
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.org/license/LICENSE.
> +#include <rtems.h>
> +  sparc_syscall_exit(RTEMS_FATAL_SOURCE_BSP, error);
