[PATCH 6/6] Use Shared Method for Thread Unblock Cleanup
Joel Sherrill
joel.sherrill at oarcorp.com
Wed Jul 9 19:22:10 UTC 2014
When a thread is removed from a thread queue or is unblocked
by receiving an event, the same actions are required.
+ timeout watchdog canceled,
+ thread must be unblocked, and
+ (MP only) proxy cleaned up
This patch makes sure there is only one copy of this code.
cpukit/score/include/rtems/score/threadimpl.h | 18 ++++++
cpukit/score/src/threadblockingoperationcancel.c | 65 ++++++++++++----------
cpukit/score/src/threadqdequeue.c | 18 +-----
cpukit/score/src/threadqextract.c | 22 ++-----
4 files changed, 63 insertions(+), 60 deletions(-)
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index 4971e9d..5327e29 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -403,6 +403,24 @@ void _Thread_blocking_operation_Cancel(
ISR_Level level
+ * @brief Finalize a blocking operation.
+ * This method is used to finalize a blocking operation that was
+ * satisfied. It may be used with thread queues or any other synchronization
+ * object that uses the blocking states and watchdog times for timeout.
+ * This method will restore the previous ISR disable level during the cancel
+ * operation. Thus it is an implicit _ISR_Enable().
+ * @param[in] the_thread is the thread whose blocking is canceled
+ * @param[in] level is the previous ISR disable level
+void _Thread_blocking_operation_Finalize(
+ Thread_Control *the_thread,
+ ISR_Level level
RTEMS_INLINE_ROUTINE Per_CPU_Control *_Thread_Get_CPU(
const Thread_Control *thread
diff --git a/cpukit/score/src/threadblockingoperationcancel.c b/cpukit/score/src/threadblockingoperationcancel.c
index 127d852..b496796 100644
--- a/cpukit/score/src/threadblockingoperationcancel.c
+++ b/cpukit/score/src/threadblockingoperationcancel.c
@@ -24,6 +24,41 @@
#endif
+ ISR_Level level
+ * The thread is not waiting on anything after this completes.
+ the_thread->Wait.queue = NULL;
+ * If the sync state is timed out, this is very likely not needed.
+ * But better safe than sorry when it comes to critical sections.
+ if ( _Watchdog_Is_active( &the_thread->Timer ) ) {
+ _Watchdog_Deactivate( &the_thread->Timer );
+ _ISR_Enable( level );
+ (void) _Watchdog_Remove( &the_thread->Timer );
+ } else
+ * Global objects with thread queue's should not be operated on from an
+ * ISR. But the sync code still must allow short timeouts to be processed
+ * correctly.
+ _Thread_Unblock( the_thread );
+#if defined(RTEMS_MULTIPROCESSING)
+ if ( !_Objects_Is_local_id( the_thread->Object.id ) )
+ _Thread_MP_Free_proxy( the_thread );
+#endif
#if defined(RTEMS_DEBUG)
Thread_blocking_operation_States sync_state,
@@ -59,33 +94,5 @@ void _Thread_blocking_operation_Cancel(
#endif
- * The thread is not waiting on anything after this completes.
- the_thread->Wait.queue = NULL;
- * If the sync state is timed out, this is very likely not needed.
- * But better safe than sorry when it comes to critical sections.
- if ( _Watchdog_Is_active( &the_thread->Timer ) ) {
- _Watchdog_Deactivate( &the_thread->Timer );
- _ISR_Enable( level );
- (void) _Watchdog_Remove( &the_thread->Timer );
- } else
- * Global objects with thread queue's should not be operated on from an
- * ISR. But the sync code still must allow short timeouts to be processed
- * correctly.
- _Thread_Unblock( the_thread );
-#if defined(RTEMS_MULTIPROCESSING)
- if ( !_Objects_Is_local_id( the_thread->Object.id ) )
- _Thread_MP_Free_proxy( the_thread );
-#endif
+ _Thread_blocking_operation_Finalize( the_thread, level );
diff --git a/cpukit/score/src/threadqdequeue.c b/cpukit/score/src/threadqdequeue.c
index 3b55e52..d745ef2 100644
--- a/cpukit/score/src/threadqdequeue.c
+++ b/cpukit/score/src/threadqdequeue.c
@@ -70,22 +70,10 @@ Thread_Control *_Thread_queue_Dequeue(
* We found a thread to unblock.
+ * NOTE: This is invoked with interrupts still disabled.
- if ( !_Watchdog_Is_active( &the_thread->Timer ) ) {
- } else {
-#endif
return the_thread;
diff --git a/cpukit/score/src/threadqextract.c b/cpukit/score/src/threadqextract.c
index bc7d346..d12d3c8 100644
--- a/cpukit/score/src/threadqextract.c
+++ b/cpukit/score/src/threadqextract.c
@@ -48,24 +48,14 @@ void _Thread_queue_Extract_with_return_code(
the_thread->Wait.return_code = return_code;
- } else {
-#endif
+ * We found a thread to unblock.
void _Thread_queue_Extract(
1.7.1
