[PATCH 3/6] smpschedaffinity03: New test.
Jennifer Averett jennifer.averett at oarcorp.com
Fri Jul 11 14:44:44 UTC 2014
This task walks the affinity of self across all the cores.
 testsuites/smptests/Makefile.am                    |   1 +
 testsuites/smptests/configure.ac                   |   1 +
 testsuites/smptests/smpschedaffinity03/Makefile.am |  19 ++++
 testsuites/smptests/smpschedaffinity03/init.c      | 101 +++++++++++++++++++++
 .../smpschedaffinity03/smpschedaffinity03.doc      |  10 ++
 .../smpschedaffinity03/smpschedaffinity03.scn      |  10 ++
 6 files changed, 142 insertions(+)
 create mode 100644 testsuites/smptests/smpschedaffinity03/Makefile.am
 create mode 100644 testsuites/smptests/smpschedaffinity03/init.c
 create mode 100644 testsuites/smptests/smpschedaffinity03/smpschedaffinity03.doc
 create mode 100644 testsuites/smptests/smpschedaffinity03/smpschedaffinity03.scn
diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
index 424fa28..961ef55 100644
--- a/testsuites/smptests/Makefile.am
+++ b/testsuites/smptests/Makefile.am
@@ -25,6 +25,7 @@ SUBDIRS += smpmigration02
 SUBDIRS += smpmrsp01
 SUBDIRS += smpschedaffinity01
 SUBDIRS += smpschedaffinity02
+SUBDIRS += smpschedaffinity03
 SUBDIRS += smpscheduler01
 SUBDIRS += smpscheduler02
 SUBDIRS += smpscheduler03
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index eac0e65..4c21646 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -83,6 +83,7 @@ smppsxaffinity02/Makefile
 smppsxsignal01/Makefile
 smpschedaffinity01/Makefile
 smpschedaffinity02/Makefile
+smpschedaffinity03/Makefile
 smpscheduler01/Makefile
 smpscheduler02/Makefile
 smpscheduler03/Makefile
diff --git a/testsuites/smptests/smpschedaffinity03/Makefile.am b/testsuites/smptests/smpschedaffinity03/Makefile.am
new file mode 100644
index 0000000..995f587
--- /dev/null
+++ b/testsuites/smptests/smpschedaffinity03/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = smpschedaffinity03
+smpschedaffinity03_SOURCES = init.c
+dist_rtems_tests_DATA = smpschedaffinity03.scn smpschedaffinity03.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(smpschedaffinity03_OBJECTS)
+LINK_LIBS = $(smpschedaffinity03_LDLIBS)
+smpschedaffinity03$(EXEEXT): $(smpschedaffinity03_OBJECTS) $(smpschedaffinity03_DEPENDENCIES)
+	@rm -f smpschedaffinity03$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/smptests/smpschedaffinity03/init.c b/testsuites/smptests/smpschedaffinity03/init.c
index 0000000..5b8acf7
--- /dev/null
+++ b/testsuites/smptests/smpschedaffinity03/init.c
@@ -0,0 +1,101 @@
+ *  COPYRIGHT (c) 2014.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+ * Test to walk the affinity of the init task across all the cores.
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "SMPSCHEDAFFINITY 3";
+#define NUM_CPUS   4
+#define TASK_COUNT NUM_CPUS
+static void test_delay(int ticks)
+  rtems_interval start, stop;
+  start = rtems_clock_get_ticks_since_boot();
+  do {
+    stop = rtems_clock_get_ticks_since_boot();
+  } while ( (stop - start) < ticks );
+static void test(void)
+  rtems_status_code   sc;
+  rtems_id            id;
+  uint32_t            cpu_count;
+  int                 cpu;
+  int                 i;
+  cpu_set_t           cpuset;
+  /* Get the number of processors that we are using. */
+  cpu_count = rtems_get_processor_count();
+  id = rtems_task_self();
+   * The Init task comes up on the maximum core so start at
+   * that core and walk the affinity down to core 0.
+  for( i=cpu_count-1; i >= 0; i--) {
+    /* Move the affinity to the current core - 1 */
+    CPU_ZERO(&cpuset);
+    CPU_SET(i, &cpuset);
+    printf("Set Affinity for cpu %d\n", i);
+    sc = rtems_task_set_affinity( id, sizeof(cpuset), &cpuset );
+    rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+    /* Wait 100 clock ticks */
+    test_delay(100);
+    /* Check the cpu the Init task is running on */
+    cpu = rtems_get_current_processor();
+    printf("On cpu %d\n", cpu);
+    rtems_test_assert(cpu == i);
+static void Init(rtems_task_argument arg)
+  TEST_BEGIN();
+  test();
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_SMP_APPLICATION
+#define CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
+#define CONFIGURE_SMP_MAXIMUM_PROCESSORS NUM_CPUS
+#define CONFIGURE_MAXIMUM_TASKS          TASK_COUNT
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+  #define CONFIGURE_INIT_TASK_PRIORITY      8
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smpschedaffinity03/smpschedaffinity03.doc b/testsuites/smptests/smpschedaffinity03/smpschedaffinity03.doc
index 0000000..5afc2d8
--- /dev/null
+++ b/testsuites/smptests/smpschedaffinity03/smpschedaffinity03.doc
@@ -0,0 +1,10 @@
+This file describes the directives and concepts tested by this test set.
+test set name: smpschedaffinity03
+directives:
+  - _Scheduler_priority_affinity_xxx
+concepts:
+ - Test to walk the affinity of the init task across all the cores.
diff --git a/testsuites/smptests/smpschedaffinity03/smpschedaffinity03.scn b/testsuites/smptests/smpschedaffinity03/smpschedaffinity03.scn
index 0000000..76e9003
--- /dev/null
+++ b/testsuites/smptests/smpschedaffinity03/smpschedaffinity03.scn
@@ -0,0 +1,10 @@
+*** BEGIN OF TEST SMPSCHEDAFFINITY 3 ***
+Set Affinity for cpu 3
+On cpu 3
+Set Affinity for cpu 2
+On cpu 2
+Set Affinity for cpu 1
+On cpu 1
+Set Affinity for cpu 0
+On cpu 0
+*** END OF TEST SMPSCHEDAFFINITY 3 ***
1.8.1.4
