[PATCH 4/6] smpschedaffinity04: New test.
Jennifer Averett jennifer.averett at oarcorp.com
Fri Jul 11 14:44:45 UTC 2014
This test walks a secondary high prority task across
all the cores.
 testsuites/smptests/Makefile.am                    |   1 +
 testsuites/smptests/configure.ac                   |   1 +
 testsuites/smptests/smpschedaffinity04/Makefile.am |  19 +++
 testsuites/smptests/smpschedaffinity04/init.c      | 184 +++++++++++++++++++++
 .../smpschedaffinity04/smpschedaffinity04.doc      |  11 ++
 .../smpschedaffinity04/smpschedaffinity04.scn      |  13 ++
 6 files changed, 229 insertions(+)
 create mode 100644 testsuites/smptests/smpschedaffinity04/Makefile.am
 create mode 100644 testsuites/smptests/smpschedaffinity04/init.c
 create mode 100644 testsuites/smptests/smpschedaffinity04/smpschedaffinity04.doc
 create mode 100644 testsuites/smptests/smpschedaffinity04/smpschedaffinity04.scn
diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
index 961ef55..e025dab 100644
--- a/testsuites/smptests/Makefile.am
+++ b/testsuites/smptests/Makefile.am
@@ -26,6 +26,7 @@ SUBDIRS += smpmrsp01
 SUBDIRS += smpschedaffinity01
 SUBDIRS += smpschedaffinity02
 SUBDIRS += smpschedaffinity03
+SUBDIRS += smpschedaffinity04
 SUBDIRS += smpscheduler01
 SUBDIRS += smpscheduler02
 SUBDIRS += smpscheduler03
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index 4c21646..cb8ac65 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -84,6 +84,7 @@ smppsxsignal01/Makefile
 smpschedaffinity01/Makefile
 smpschedaffinity02/Makefile
 smpschedaffinity03/Makefile
+smpschedaffinity04/Makefile
 smpscheduler01/Makefile
 smpscheduler02/Makefile
 smpscheduler03/Makefile
diff --git a/testsuites/smptests/smpschedaffinity04/Makefile.am b/testsuites/smptests/smpschedaffinity04/Makefile.am
new file mode 100644
index 0000000..d75216c
--- /dev/null
+++ b/testsuites/smptests/smpschedaffinity04/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = smpschedaffinity04
+smpschedaffinity04_SOURCES = init.c
+dist_rtems_tests_DATA = smpschedaffinity04.scn smpschedaffinity04.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(smpschedaffinity04_OBJECTS)
+LINK_LIBS = $(smpschedaffinity04_LDLIBS)
+smpschedaffinity04$(EXEEXT): $(smpschedaffinity04_OBJECTS) $(smpschedaffinity04_DEPENDENCIES)
+	@rm -f smpschedaffinity04$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/smptests/smpschedaffinity04/init.c b/testsuites/smptests/smpschedaffinity04/init.c
index 0000000..bdfc56c
--- /dev/null
+++ b/testsuites/smptests/smpschedaffinity04/init.c
@@ -0,0 +1,184 @@
+ *  COPYRIGHT (c) 2014.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+ * Use the Init task to walk the higher priority TA1 across all the cores.
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "SMPSCHEDAFFINITY 4";
+#define NUM_CPUS   4
+#define TASK_COUNT 2
+struct task_data_t {
+  rtems_id   id;
+  int        expected_cpu;
+  bool       ran;
+  int        actual_cpu;
+struct task_data_t task_data = {
+  0x0, 2, false, 0xff
+rtems_id           task_sem;
+static void task(rtems_task_argument arg);
+static void test_delay(int ticks)
+  rtems_interval start, stop;
+  start = rtems_clock_get_ticks_since_boot();
+  do {
+    stop = rtems_clock_get_ticks_since_boot();
+  } while ( (stop - start) < ticks );
+ * Task that continually sets the cpu and
+ * run indicators without blocking.
+  rtems_status_code   sc;
+  while (true) {
+    sc = rtems_semaphore_obtain (task_sem, RTEMS_NO_WAIT, 0);
+    if (sc == RTEMS_SUCCESSFUL) {
+      task_data.ran = true;
+      task_data.actual_cpu = rtems_get_current_processor();
+      rtems_semaphore_release(task_sem);
+static void test(void)
+  uint32_t            cpu_count;
+  int                 cpu;
+  int                 i;
+  cpu_set_t           cpuset;
+  /* Get the number of processors that we are using. */
+  cpu_count = rtems_get_processor_count();
+  if (cpu_count < 2) {
+    printf("Error: Test requires at least 2 cpus\n");
+    return;
+  printf("Create Semaphore\n");
+  sc = rtems_semaphore_create(
+    rtems_build_name('S', 'E', 'M', '0'),
+    1,                                               /* initial count = 1 */
+    RTEMS_LOCAL                   |
+    RTEMS_SIMPLE_BINARY_SEMAPHORE |
+    RTEMS_NO_INHERIT_PRIORITY     |
+    RTEMS_NO_PRIORITY_CEILING     |
+    RTEMS_FIFO,
+    0,
+    &task_sem
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+   * Create and start TA1 at a higher priority
+   * than the init task.
+  sc = rtems_task_create(
+    rtems_build_name('T', 'A', '0', '1'),
+    4,
+    RTEMS_MINIMUM_STACK_SIZE,
+    RTEMS_DEFAULT_MODES,
+    RTEMS_DEFAULT_ATTRIBUTES,
+    &task_data.id
+  printf("Start TA1\n");
+  sc = rtems_task_start( task_data.id, task, 0 );
+   * Verify the Init task is running on the max core.
+  printf("Verify Init task is on cpu %ld\n",cpu_count-1);
+  cpu = rtems_get_current_processor();
+  rtems_test_assert(cpu == (cpu_count-1));
+  /* Walk TA1 across all of the cores */
+  for(i=0; i < cpu_count; i++) {
+    /* Set the Affinity to core i */
+    CPU_ZERO(&cpuset);
+    CPU_SET(i, &cpuset);
+    printf("Set Affinity TA1 to cpu %d\n", i);
+    sc = rtems_task_set_affinity( task_data.id, sizeof(cpuset), &cpuset );
+    /* Wait a bit to be sure it has switched cores then clear the task data */
+    test_delay(50);
+    while( rtems_semaphore_obtain (task_sem, RTEMS_NO_WAIT, 0) != RTEMS_SUCCESSFUL );
+    task_data.ran = false;
+    task_data.expected_cpu = i;
+    test_delay(50);
+    /* Verify the task ran on core i */
+    if (task_data.ran != true)
+      printf("Error: TA01 never ran.\n");
+    else
+      printf(
+        "TA1 expected cpu: %d actual cpu %d\n",
+        task_data.expected_cpu,
+    rtems_test_assert(task_data.ran == true);
+    rtems_test_assert(task_data.expected_cpu == task_data.actual_cpu);
+static void Init(rtems_task_argument arg)
+  TEST_BEGIN();
+  test();
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_SMP_APPLICATION
+#define CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
+#define CONFIGURE_SMP_MAXIMUM_PROCESSORS NUM_CPUS
+#define CONFIGURE_MAXIMUM_TASKS          TASK_COUNT
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_INIT_TASK_PRIORITY      8
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smpschedaffinity04/smpschedaffinity04.doc b/testsuites/smptests/smpschedaffinity04/smpschedaffinity04.doc
index 0000000..27cf029
--- /dev/null
+++ b/testsuites/smptests/smpschedaffinity04/smpschedaffinity04.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: smpschedaffinity04
+directives:
+  - _Scheduler_priority_affinity_xxx
+concepts:
+ - Use the Init task to walk the higher priority TA1 across all the cores.
diff --git a/testsuites/smptests/smpschedaffinity04/smpschedaffinity04.scn b/testsuites/smptests/smpschedaffinity04/smpschedaffinity04.scn
index 0000000..8d4c7d3
--- /dev/null
+++ b/testsuites/smptests/smpschedaffinity04/smpschedaffinity04.scn
@@ -0,0 +1,13 @@
+*** BEGIN OF TEST SMPSCHEDAFFINITY 4 ***
+Create Semaphore
+Start TA1
+Verify Init task is on cpu 3
+Set Affinity TA1 to cpu 0
+TA1 expected cpu: 0 actual cpu 0
+Set Affinity TA1 to cpu 1
+TA1 expected cpu: 1 actual cpu 1
+Set Affinity TA1 to cpu 2
+TA1 expected cpu: 2 actual cpu 2
+Set Affinity TA1 to cpu 3
+TA1 expected cpu: 3 actual cpu 3
+*** END OF TEST SMPSCHEDAFFINITY 4 ***
1.8.1.4
