Zynq BSP
emanuel stiebler emu at e-bbes.com
Fri Jul 18 22:39:23 UTC 2014
On 2014-07-18 09:39, Giovanni Macciocu wrote:
> Hi Emanuel,
> RTEMS has a BSP which is named xilinx_zynq_zedboard, I use the following configuration to build RTEMS for this BSP.
>   $ ../configure --target=arm-rtems4.11 --enable-rtemsbsp=xilinx_zynq_zedboard --prefix=/opt/rtems-4.11 --enable-posix --enable-networking
Hello Giovanni,
Yes, I noticed that. But I was hoping for a little write up, or how-to,
on how to use it, or how is it intended to be used.
We still use the U-Boot to load it?
Cheers & thanks
