[PATCH 1/3] rbtree: Format
Mon Jul 21 16:57:06 UTC 2014
There could be something wrong here but I don't see it on a quick review.
On 7/21/2014 11:31 AM, Sebastian Huber wrote:
>  cpukit/score/src/rbtree.c        |   7 +-
>  cpukit/score/src/rbtreeextract.c | 152 +++++++++++++++++++++------------------
>  cpukit/score/src/rbtreefind.c    |   7 +-
>  cpukit/score/src/rbtreeinsert.c  |  69 ++++++++++--------
>  cpukit/score/src/rbtreeiterate.c |  12 ++--
>  cpukit/score/src/rbtreenext.c    |  13 ++--
>  6 files changed, 143 insertions(+), 117 deletions(-)
> diff --git a/cpukit/score/src/rbtree.c b/cpukit/score/src/rbtree.c
> index 5e8520d..2138a81 100644
> --- a/cpukit/score/src/rbtree.c
> +++ b/cpukit/score/src/rbtree.c
> @@ -31,17 +31,18 @@ void _RBTree_Initialize(
>    bool            is_unique
> -  size_t      count;
> +  size_t       count;
>    RBTree_Node *next;
>    /* TODO: Error message? */
> -  if (!the_rbtree) return;
> +  if ( !the_rbtree ) return;
>    /* could do sanity checks here */
>    _RBTree_Initialize_empty( the_rbtree );
>    count = number_nodes;
> -  next  = starting_address;
> +  next = starting_address;
>    while ( count-- ) {
>      _RBTree_Insert( the_rbtree, next, compare, is_unique );
>      next = (RBTree_Node *) _Addresses_Add_offset( next, node_size );
> diff --git a/cpukit/score/src/rbtreeextract.c b/cpukit/score/src/rbtreeextract.c
> index 9e87868..2638f63 100644
> --- a/cpukit/score/src/rbtreeextract.c
> +++ b/cpukit/score/src/rbtreeextract.c
> @@ -21,45 +21,45 @@
>   *  @note It does NOT disable interrupts to ensure the atomicity
>   *        of the extract operation.
> -static void _RBTree_Extract_validate(
> -    RBTree_Node *the_node
> +static void _RBTree_Extract_validate( RBTree_Node *the_node )
> -  RBTree_Node *parent, *sibling;
> +  RBTree_Node     *parent, *sibling;
>    RBTree_Direction dir;
>    parent = the_node->parent;
> -  if(!parent->parent) return;
> -  sibling = _RBTree_Sibling(the_node);
> +  if ( !parent->parent ) return;
> -  /* continue to correct tree as long as the_node is black and not the root */
> -  while (!_RBTree_Is_red(the_node) && parent->parent) {
> +  sibling = _RBTree_Sibling( the_node );
> +  /* continue to correct tree as long as the_node is black and not the root */
> +  while ( !_RBTree_Is_red( the_node ) && parent->parent ) {
>      /* if sibling is red, switch parent (black) and sibling colors,
>       * then rotate parent left, making the sibling be the_node's grandparent.
>       * Now the_node has a black sibling and red parent. After rotation,
>       * update sibling pointer.
> -    if (_RBTree_Is_red(sibling)) {
> +    if ( _RBTree_Is_red( sibling ) ) {
>        parent->color = RBT_RED;
>        sibling->color = RBT_BLACK;
> -      dir = the_node != parent->child[0];
> -      _RBTree_Rotate(parent, dir);
> -      sibling = parent->child[_RBTree_Opposite_direction(dir)];
> +      dir = the_node != parent->child[ 0 ];
> +      _RBTree_Rotate( parent, dir );
> +      sibling = parent->child[ _RBTree_Opposite_direction( dir ) ];
>      /* sibling is black, see if both of its children are also black. */
> -    if (!_RBTree_Is_red(sibling->child[RBT_RIGHT]) &&
> -        !_RBTree_Is_red(sibling->child[RBT_LEFT])) {
> -        sibling->color = RBT_RED;
> -        if (_RBTree_Is_red(parent)) {
> -          parent->color = RBT_BLACK;
> -          break;
> -        the_node = parent; /* done if parent is red */
> -        parent = the_node->parent;
> +    if ( !_RBTree_Is_red( sibling->child[ RBT_RIGHT ] ) &&
> +         !_RBTree_Is_red( sibling->child[ RBT_LEFT ] ) ) {
> +      sibling->color = RBT_RED;
> +      if ( _RBTree_Is_red( parent ) ) {
> +        parent->color = RBT_BLACK;
> +        break;
> +      the_node = parent;   /* done if parent is red */
> +      parent = the_node->parent;
>      } else {
>        /* at least one of sibling's children is red. we now proceed in two
>         * cases, either the_node is to the left or the right of the parent.
> @@ -67,21 +67,27 @@ static void _RBTree_Extract_validate(
>         * and if so rotate in the proper direction and update sibling pointer.
>         * Then switch the sibling and parent colors, and rotate through parent.
> -      if (!_RBTree_Is_red(sibling->child[_RBTree_Opposite_direction(dir)])) {
> +      if (
> +        !_RBTree_Is_red( sibling->child[ _RBTree_Opposite_direction( dir ) ] )
> -        sibling->child[dir]->color = RBT_BLACK;
> -        _RBTree_Rotate(sibling, _RBTree_Opposite_direction(dir));
> +        sibling->child[ dir ]->color = RBT_BLACK;
> +        _RBTree_Rotate( sibling, _RBTree_Opposite_direction( dir ) );
>        sibling->color = parent->color;
> -      sibling->child[_RBTree_Opposite_direction(dir)]->color = RBT_BLACK;
> +      sibling->child[ _RBTree_Opposite_direction( dir ) ]->color = RBT_BLACK;
>        break; /* done */
>    } /* while */
> -  if(!the_node->parent->parent) the_node->color = RBT_BLACK;
> +  if ( !the_node->parent->parent )
> +    the_node->color = RBT_BLACK;
>  /** @brief Extract a Node (unprotected)
> @@ -92,29 +98,29 @@ static void _RBTree_Extract_validate(
>  void _RBTree_Extract(
> -    RBTree_Control *the_rbtree,
> +  RBTree_Control *the_rbtree,
> +  RBTree_Node    *the_node
> -  RBTree_Node *leaf, *target;
> -  RBTree_Color victim_color;
> +  RBTree_Node     *leaf, *target;
> +  RBTree_Color     victim_color;
> -  if (!the_node) return;
> +  if ( !the_node ) return;
>    /* check if min needs to be updated */
> -  if (the_node == the_rbtree->first[RBT_LEFT]) {
> +  if ( the_node == the_rbtree->first[ RBT_LEFT ] ) {
>      RBTree_Node *next;
> -    next = _RBTree_Successor(the_node);
> -    the_rbtree->first[RBT_LEFT] = next;
> +    next = _RBTree_Successor( the_node );
> +    the_rbtree->first[ RBT_LEFT ] = next;
>    /* Check if max needs to be updated. min=max for 1 element trees so
>     * do not use else if here. */
> -  if (the_node == the_rbtree->first[RBT_RIGHT]) {
> +  if ( the_node == the_rbtree->first[ RBT_RIGHT ] ) {
>      RBTree_Node *previous;
> -    previous = _RBTree_Predecessor(the_node);
> -    the_rbtree->first[RBT_RIGHT] = previous;
> +    previous = _RBTree_Predecessor( the_node );
> +    the_rbtree->first[ RBT_RIGHT ] = previous;
>    /* if the_node has at most one non-null child then it is safe to proceed
> @@ -124,9 +130,11 @@ void _RBTree_Extract(
>     * search tree property, but may violate the red-black properties.
> -  if (the_node->child[RBT_LEFT] && the_node->child[RBT_RIGHT]) {
> -    target = the_node->child[RBT_LEFT]; /* find max in node->child[RBT_LEFT] */
> -    while (target->child[RBT_RIGHT]) target = target->child[RBT_RIGHT];
> +  if ( the_node->child[ RBT_LEFT ] && the_node->child[ RBT_RIGHT ] ) {
> +    target = the_node->child[ RBT_LEFT ]; /* find max in node->child[RBT_LEFT] */
> +    while ( target->child[ RBT_RIGHT ] )
> +      target = target->child[ RBT_RIGHT ];
>      /* if the target node has a child, need to move it up the tree into
>       * target's position (target is the right child of target->parent)
> @@ -134,28 +142,33 @@ void _RBTree_Extract(
>       * should become NULL. This may cause the coloring to be violated.
>       * For now we store the color of the node being deleted in victim_color.
> -    leaf = target->child[RBT_LEFT];
> -    if(leaf) {
> +    leaf = target->child[ RBT_LEFT ];
> +    if ( leaf ) {
>        leaf->parent = target->parent;
>      } else {
>        /* fix the tree here if the child is a null leaf. */
> -      _RBTree_Extract_validate(target);
> +      _RBTree_Extract_validate( target );
>      victim_color = target->color;
> -    dir = target != target->parent->child[0];
> -    target->parent->child[dir] = leaf;
> +    dir = target != target->parent->child[ 0 ];
> +    target->parent->child[ dir ] = leaf;
>      /* now replace the_node with target */
> -    dir = the_node != the_node->parent->child[0];
> -    the_node->parent->child[dir] = target;
> +    dir = the_node != the_node->parent->child[ 0 ];
> +    the_node->parent->child[ dir ] = target;
>      /* set target's new children to the original node's children */
> -    target->child[RBT_RIGHT] = the_node->child[RBT_RIGHT];
> -    if (the_node->child[RBT_RIGHT])
> -      the_node->child[RBT_RIGHT]->parent = target;
> -    target->child[RBT_LEFT] = the_node->child[RBT_LEFT];
> -    if (the_node->child[RBT_LEFT])
> -      the_node->child[RBT_LEFT]->parent = target;
> +    target->child[ RBT_RIGHT ] = the_node->child[ RBT_RIGHT ];
> +    if ( the_node->child[ RBT_RIGHT ] )
> +      the_node->child[ RBT_RIGHT ]->parent = target;
> +    target->child[ RBT_LEFT ] = the_node->child[ RBT_LEFT ];
> +    if ( the_node->child[ RBT_LEFT ] )
> +      the_node->child[ RBT_LEFT ]->parent = target;
>      /* finally, update the parent node and recolor. target has completely
>       * replaced the_node, and target's child has moved up the tree if needed.
> @@ -170,19 +183,21 @@ void _RBTree_Extract(
>       * violated. We will fix it later.
> -    leaf = the_node->child[RBT_LEFT] ?
> -              the_node->child[RBT_LEFT] : the_node->child[RBT_RIGHT];
> -    if( leaf ) {
> +    leaf = the_node->child[ RBT_LEFT ] ?
> +           the_node->child[ RBT_LEFT ] : the_node->child[ RBT_RIGHT ];
> +    if ( leaf ) {
>        leaf->parent = the_node->parent;
>      } else {
> -      _RBTree_Extract_validate(the_node);
> +      _RBTree_Extract_validate( the_node );
>      victim_color = the_node->color;
>      /* remove the_node from the tree */
> -    the_node->parent->child[dir] = leaf;
> +    the_node->parent->child[ dir ] = leaf;
>    /* fix coloring. leaf has moved up the tree. The color of the deleted
> @@ -190,15 +205,16 @@ void _RBTree_Extract(
>     *   1. Deleted a red node, its child must be black. Nothing must be done.
>     *   2. Deleted a black node, its child must be red. Paint child black.
> -  if (victim_color == RBT_BLACK) { /* eliminate case 1 */
> -    if (leaf) {
> +  if ( victim_color == RBT_BLACK ) { /* eliminate case 1 */
> +    if ( leaf ) {
>        leaf->color = RBT_BLACK; /* case 2 */
>    /* Wipe the_node */
> -  _RBTree_Set_off_rbtree(the_node);
> +  _RBTree_Set_off_rbtree( the_node );
>    /* set root to black, if it exists */
> -  if (the_rbtree->root) the_rbtree->root->color = RBT_BLACK;
> +  if ( the_rbtree->root )
> +    the_rbtree->root->color = RBT_BLACK;
> diff --git a/cpukit/score/src/rbtreefind.c b/cpukit/score/src/rbtreefind.c
> index ad0c9fd..f767626 100644
> --- a/cpukit/score/src/rbtreefind.c
> +++ b/cpukit/score/src/rbtreefind.c
> @@ -26,15 +26,16 @@ RBTree_Node *_RBTree_Find(
>    bool                  is_unique
> -  RBTree_Node* iter_node = the_rbtree->root;
> -  RBTree_Node* found = NULL;
> +  RBTree_Node *iter_node = the_rbtree->root;
> +  RBTree_Node *found = NULL;
>    while ( iter_node != NULL ) {
> -    int compare_result = ( *compare )( the_node, iter_node );
> +    int              compare_result = ( *compare )( the_node, iter_node );
>      if ( _RBTree_Is_equal( compare_result ) ) {
>        found = iter_node;
>        if ( is_unique )
>          break;
> diff --git a/cpukit/score/src/rbtreeinsert.c b/cpukit/score/src/rbtreeinsert.c
> index 7174529..369ef26 100644
> --- a/cpukit/score/src/rbtreeinsert.c
> +++ b/cpukit/score/src/rbtreeinsert.c
> @@ -21,42 +21,43 @@
>   *  @note It does NOT disable interrupts to ensure the atomicity of the
>   *        append operation.
> -static void _RBTree_Validate_insert(
> +static void _RBTree_Validate_insert( RBTree_Node *the_node )
> -  RBTree_Node *u,*g;
> +  RBTree_Node *u, *g;
>    /* note: the insert root case is handled already */
>    /* if the parent is black, nothing needs to be done
>     * otherwise may need to loop a few times */
> -  while (_RBTree_Is_red(_RBTree_Parent(the_node))) {
> -    u = _RBTree_Parent_sibling(the_node);
> +  while ( _RBTree_Is_red( _RBTree_Parent( the_node ) ) ) {
> +    u = _RBTree_Parent_sibling( the_node );
>      g = the_node->parent->parent;
>      /* if uncle is red, repaint uncle/parent black and grandparent red */
> -    if(_RBTree_Is_red(u)) {
> +    if ( _RBTree_Is_red( u ) ) {
>        the_node->parent->color = RBT_BLACK;
>        u->color = RBT_BLACK;
>        g->color = RBT_RED;
>        the_node = g;
>      } else { /* if uncle is black */
> -      RBTree_Direction dir = the_node != the_node->parent->child[0];
> -      RBTree_Direction pdir = the_node->parent != g->child[0];
> +      RBTree_Direction dir = the_node != the_node->parent->child[ 0 ];
> +      RBTree_Direction pdir = the_node->parent != g->child[ 0 ];
>        /* ensure node is on the same branch direction as parent */
> -      if (dir != pdir) {
> -        _RBTree_Rotate(the_node->parent, pdir);
> -        the_node = the_node->child[pdir];
> +      if ( dir != pdir ) {
> +        _RBTree_Rotate( the_node->parent, pdir );
> +        the_node = the_node->child[ pdir ];
>        g->color = RBT_RED;
>        /* now rotate grandparent in the other branch direction (toward uncle) */
> -      _RBTree_Rotate(g, (1-pdir));
> +      _RBTree_Rotate( g, ( 1 - pdir ) );
>  RBTree_Node *_RBTree_Insert(
> @@ -66,47 +67,53 @@ RBTree_Node *_RBTree_Insert(
>    bool            is_unique
> -  if(!the_node) return (RBTree_Node*)-1;
> +  if ( !the_node ) return (RBTree_Node *) -1;
> -  int compare_result;
> -  if (!iter_node) { /* special case: first node inserted */
> +  if ( !iter_node ) { /* special case: first node inserted */
>      the_rbtree->root = the_node;
> -    the_rbtree->first[0] = the_rbtree->first[1] = the_node;
> +    the_rbtree->first[ 0 ] = the_rbtree->first[ 1 ] = the_node;
>      the_node->parent = (RBTree_Node *) the_rbtree;
> -    the_node->child[RBT_LEFT] = the_node->child[RBT_RIGHT] = NULL;
> +    the_node->child[ RBT_LEFT ] = the_node->child[ RBT_RIGHT ] = NULL;
>    } else {
>      /* typical binary search tree insert, descend tree to leaf and insert */
> -    while (iter_node) {
> -      compare_result = ( *compare )( the_node, iter_node );
> +    while ( iter_node ) {
>        if ( is_unique && _RBTree_Is_equal( compare_result ) )
>          return iter_node;
>        RBTree_Direction dir = !_RBTree_Is_lesser( compare_result );
> -      if (!iter_node->child[dir]) {
> +      if ( !iter_node->child[ dir ] ) {
>          the_node->color = RBT_RED;
> -        iter_node->child[dir] = the_node;
> +        iter_node->child[ dir ] = the_node;
>          the_node->parent = iter_node;
>          /* update min/max */
>            the_node,
>            _RBTree_First( the_rbtree, dir )
> -        if ( (!dir && _RBTree_Is_lesser(compare_result)) ||
> -              (dir && _RBTree_Is_greater(compare_result)) ) {
> -          the_rbtree->first[dir] = the_node;
> +        if (
> +          ( !dir && _RBTree_Is_lesser( compare_result ) )
> +            || ( dir && _RBTree_Is_greater( compare_result ) )
> +          the_rbtree->first[ dir ] = the_node;
>          break;
>        } else {
> -        iter_node = iter_node->child[dir];
> +        iter_node = iter_node->child[ dir ];
>      } /* while(iter_node) */
>      /* verify red-black properties */
> -    _RBTree_Validate_insert(the_node);
> +    _RBTree_Validate_insert( the_node );
> -  return (RBTree_Node*)0;
> +  return (RBTree_Node *) 0;
> diff --git a/cpukit/score/src/rbtreeiterate.c b/cpukit/score/src/rbtreeiterate.c
> index f325567..8b5da1e 100644
> --- a/cpukit/score/src/rbtreeiterate.c
> +++ b/cpukit/score/src/rbtreeiterate.c
> @@ -28,17 +28,17 @@
>  void _RBTree_Iterate(
>    const RBTree_Control *rbtree,
> -  RBTree_Direction dir,
> -  RBTree_Visitor visitor,
> -  void *visitor_arg
> +  RBTree_Direction      dir,
> +  RBTree_Visitor        visitor,
> +  void                 *visitor_arg
> -  RBTree_Direction opp_dir = _RBTree_Opposite_direction( dir );
> +  RBTree_Direction   opp_dir = _RBTree_Opposite_direction( dir );
>    const RBTree_Node *current = _RBTree_First( rbtree, opp_dir );
> -  bool stop = false;
> +  bool               stop = false;
>    while ( !stop && current != NULL ) {
> -    stop = (*visitor)( current, dir, visitor_arg );
> +    stop = ( *visitor )( current, dir, visitor_arg );
>      current = _RBTree_Next( current, dir );
> diff --git a/cpukit/score/src/rbtreenext.c b/cpukit/score/src/rbtreenext.c
> index fde0bc6..2128ae5 100644
> --- a/cpukit/score/src/rbtreenext.c
> +++ b/cpukit/score/src/rbtreenext.c
> @@ -29,25 +29,26 @@
>  RBTree_Node *_RBTree_Next(
>    const RBTree_Node *node,
> -  RBTree_Node *current = node->child [dir];
> -  RBTree_Node *next = NULL;
> +  RBTree_Node     *current = node->child[ dir ];
> +  RBTree_Node     *next = NULL;
>    if ( current != NULL ) {
>      next = current;
> -    while ( (current = current->child [opp_dir]) != NULL ) {
> +    while ( ( current = current->child[ opp_dir ] ) != NULL ) {
>        next = current;
>    } else {
>      RBTree_Node *parent = node->parent;
> -    if ( parent->parent && node == parent->child [opp_dir] ) {
> +    if ( parent->parent && node == parent->child[ opp_dir ] ) {
>        next = parent;
>      } else {
> -      while ( parent->parent && node == parent->child [dir] ) {
> +      while ( parent->parent && node == parent->child[ dir ] ) {
>          node = parent;
>          parent = parent->parent;
> 1.8.1.4
> devel mailing list
> devel at rtems.org
