[PATCH 3/3] rbtree: Do not set node off-tree in extract
Mon Jul 21 17:57:34 UTC 2014
On 7/21/2014 12:54 PM, Sebastian Huber wrote:
> On 07/21/2014 07:23 PM, Joel Sherrill wrote:
>> Unless the chain has changed to have the property of
>> "dangerous to extract if not on", this should be OK.
>> My thinking is that higher level code would be checking a state
>> of some sort and know whether to extract from the underlying
>> chain or rbtree container.
>> Is this true?  If so, this looks OK.
> Yes, this is analogous to the chains.  The lowest level implementation
> should not do consistency checks (except via _Assert()).
Thanks. Then OK.
