[PATCH 3/3] rbtree: Do not set node off-tree in extract
Mon Jul 21 17:23:21 UTC 2014
Unless the chain has changed to have the property of
"dangerous to extract if not on", this should be OK.
My thinking is that higher level code would be checking a state
of some sort and know whether to extract from the underlying
chain or rbtree container.
Is this true?  If so, this looks OK.
On 7/21/2014 11:31 AM, Sebastian Huber wrote:
>  cpukit/score/include/rtems/score/rbtree.h | 11 +++++++++--
>  cpukit/score/src/rbtreeextract.c          |  3 ---
>  testsuites/sptests/sprbtree01/init.c      |  5 +++++
>  3 files changed, 14 insertions(+), 5 deletions(-)
> diff --git a/cpukit/score/include/rtems/score/rbtree.h b/cpukit/score/include/rtems/score/rbtree.h
> index aa7b86e..54383aa 100644
> --- a/cpukit/score/include/rtems/score/rbtree.h
> +++ b/cpukit/score/include/rtems/score/rbtree.h
> @@ -241,9 +241,16 @@ RBTree_Node *_RBTree_Insert(
> - *  @brief Extracts (removes) @a the_node from @a the_rbtree.
> + * @brief Extracts (removes) the node from the red-black tree.
> - *  This routine extracts (removes) @a the_node from @a the_rbtree.
> + * This function does not set the node off-tree.  In case this is desired, then
> + * call _RBTree_Set_off_rbtree() after the extraction.
> + * In case the node to extract is not a node of the tree, then this function
> + * yields unpredictable results.
> + * @param[in] the_rbtree The red-black tree control.
> + * @param[in] the_node The node to extract.
>  void _RBTree_Extract(
>    RBTree_Control *the_rbtree,
> diff --git a/cpukit/score/src/rbtreeextract.c b/cpukit/score/src/rbtreeextract.c
> index 7775b2f..5a64ac4 100644
> --- a/cpukit/score/src/rbtreeextract.c
> +++ b/cpukit/score/src/rbtreeextract.c
> @@ -201,9 +201,6 @@ void _RBTree_Extract(
> -  /* Wipe the_node */
> -  _RBTree_Set_off_rbtree( the_node );
>    /* set root to black, if it exists */
>    if ( the_rbtree->root )
>      the_rbtree->root->color = RBT_BLACK;
> diff --git a/testsuites/sptests/sprbtree01/init.c b/testsuites/sptests/sprbtree01/init.c
> index ca79095..2359fac 100644
> --- a/testsuites/sptests/sprbtree01/init.c
> +++ b/testsuites/sptests/sprbtree01/init.c
> @@ -140,6 +140,9 @@ rtems_task Init(
>    puts( "Init - Initialize rbtree empty" );
>    rtems_rbtree_initialize_empty( &rbtree1 );
> +  rtems_rbtree_set_off_rbtree( &node1.Node );
> +  rtems_assert( rtems_rbtree_is_node_off_rbtree( &node1.Node ) );
>    /* verify that the rbtree insert work */
>    puts( "INIT - Verify rtems_rbtree_insert with two nodes" );
>    node1.id = 1;
> @@ -149,6 +152,7 @@ rtems_task Init(
>    rb_insert_unique( &rbtree1, &node1.Node );
>    rb_insert_unique( &rbtree1, &node2.Node );
> +  rtems_assert( !rtems_rbtree_is_node_off_rbtree( &node1.Node ) );
>    _RBTree_Rotate(NULL, RBT_LEFT);
>    i = (node1.Node.parent == &node2.Node);
> @@ -261,6 +265,7 @@ rtems_task Init(
>      puts( "INIT - rtems_rbtree_extract failed");
>      rtems_test_exit(0);
> +  rtems_assert( !rtems_rbtree_is_node_off_rbtree( p ) );
>    rb_insert_unique(&rbtree1, p);
>    for ( p = rtems_rbtree_get_min(&rbtree1), id = 1 ; p ;
