[PATCH 3/3] rbtree: Do not set node off-tree in extract
Mon Jul 21 17:54:08 UTC 2014
On 07/21/2014 07:23 PM, Joel Sherrill wrote:
> Unless the chain has changed to have the property of
> "dangerous to extract if not on", this should be OK.
> My thinking is that higher level code would be checking a state
> of some sort and know whether to extract from the underlying
> chain or rbtree container.
> Is this true?  If so, this looks OK.
Yes, this is analogous to the chains.  The lowest level implementation
should not do consistency checks (except via _Assert()).
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
