[PATCH] Add nios2-*-rtems* (v2 for gcc head and 4.9)
Tue Jul 22 21:54:18 UTC 2014
Please review before I send to gcc.
Thanks.
2014-07-17  Sebastian Huber  <sebastian.huber at embedded-brains.de>
            Chris Johns <chrisj at rtems.org>
            Joel Sherrill <joel.sherrill at oarcorp.com>
	* config.gcc: Add nios2-*-rtems*.
	* config/nios2/rtems.h: New file.
	* gcc/config/nios2/t-rtems: New file.
 gcc/ChangeLog            |   3 +-
 gcc/config.gcc           |   6 ++-
 gcc/config/nios2/rtems.h |  32 ++++++++++++
 gcc/config/nios2/t-rtems | 133 +++++++++++++++++++++++++++++++++++++++++++++++
 4 files changed, 171 insertions(+), 3 deletions(-)
 create mode 100644 gcc/config/nios2/rtems.h
 create mode 100644 gcc/config/nios2/t-rtems
diff --git a/gcc/ChangeLog b/gcc/ChangeLog
index ccc2b97..0c4322b 100644
--- a/gcc/ChangeLog
+++ b/gcc/ChangeLog
@@ -243,8 +243,7 @@
 	set_comdat_group to NULL_TREE.
 	(verify_symtab): Fix diagnostic.
-2014-07-16  David Wohlferd  <dw at LimeGreenSocks.com>
+2014-07-16  David Wohlferd <dw at LimeGreenSocks.com>
 	PR target/61662
 	* config/i386/ia32intrin.h: Use __LP64__ to determine size of long.
diff --git a/gcc/config.gcc b/gcc/config.gcc
index aa2d1a9..9b3637e 100644
--- a/gcc/config.gcc
+++ b/gcc/config.gcc
@@ -419,7 +419,7 @@ nds32*)
 nios2-*-*)
 	cpu_type=nios2
 	extra_options="${extra_options} g.opt"
 picochip-*-*)
         cpu_type=picochip
@@ -2136,6 +2136,10 @@ nios2-*-*)
 		tm_file="${tm_file} newlib-stdint.h nios2/elf.h"
 		extra_options="${extra_options} nios2/elf.opt"
+	nios2-*-rtems*)
+		tm_file="${tm_file} newlib-stdint.h nios2/rtems.h rtems.h"
+		tmake_file="${tmake_file} t-rtems nios2/t-rtems"
         esac
 pdp11-*-*)
diff --git a/gcc/config/nios2/rtems.h b/gcc/config/nios2/rtems.h
new file mode 100644
index 0000000..d085980
--- /dev/null
+++ b/gcc/config/nios2/rtems.h
@@ -0,0 +1,32 @@
+/* Definitions for rtems targeting a NIOS2 using ELF.
+   Contributed by Chris Johns (chrisj at rtems.org).
+This file is part of GCC.
+GCC is free software; you can redistribute it and/or modify
+it under the terms of the GNU General Public License as published by
+the Free Software Foundation; either version 3, or (at your option)
+any later version.
+GCC is distributed in the hope that it will be useful,
+but WITHOUT ANY WARRANTY; without even the implied warranty of
+MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+GNU General Public License for more details.
+You should have received a copy of the GNU General Public License
+along with GCC; see the file COPYING3.  If not see
+<http://www.gnu.org/licenses/>.  */
+/* Specify predefined symbols in preprocessor.  */
+#define TARGET_OS_CPP_BUILTINS()        \
+do {                                    \
+  builtin_define ("__rtems__");         \
+  builtin_define ("__USE_INIT_FINI__"); \
+  builtin_assert ("system=rtems");      \
+} while (0)
+/* This toolchain implements the ABI for Linux Systems documented in the
+   Nios II Processor Reference Handbook.
+   This is done so RTEMS targets have Thread Local Storage like Linux.  */
+#define TARGET_LINUX_ABI 1
diff --git a/gcc/config/nios2/t-rtems b/gcc/config/nios2/t-rtems
index 0000000..f95fa3c
--- /dev/null
+++ b/gcc/config/nios2/t-rtems
@@ -0,0 +1,133 @@
+# Custom RTEMS multilibs
+MULTILIB_OPTIONS = mhw-mul mhw-mulx mhw-div mcustom-fadds=253 mcustom-fdivs=255 mcustom-fmuls=252 mcustom-fsubs=254
+# Enumeration of multilibs
+# MULTILIB_EXCEPTIONS += mhw-mul/mhw-mulx/mhw-div/mcustom-fadds=253/mcustom-fdivs=255/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-mulx/mhw-div/mcustom-fadds=253/mcustom-fdivs=255/mcustom-fmuls=252
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-mulx/mhw-div/mcustom-fadds=253/mcustom-fdivs=255/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-mulx/mhw-div/mcustom-fadds=253/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-mulx/mhw-div/mcustom-fadds=253/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-mulx/mhw-div/mcustom-fdivs=255/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-mulx/mhw-div/mcustom-fdivs=255/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-mulx/mhw-div/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-mulx/mhw-div/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-mulx/mcustom-fadds=253/mcustom-fdivs=255/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-mulx/mcustom-fadds=253/mcustom-fdivs=255/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-mulx/mcustom-fadds=253/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-mulx/mcustom-fadds=253/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-mulx/mcustom-fdivs=255/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-mulx/mcustom-fdivs=255/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-mulx/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-mulx/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-div/mcustom-fadds=253/mcustom-fdivs=255/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-div/mcustom-fadds=253/mcustom-fdivs=255/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-div/mcustom-fadds=253/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-div/mcustom-fadds=253/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-div/mcustom-fdivs=255/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-div/mcustom-fdivs=255/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-div/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mhw-div/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mcustom-fadds=253/mcustom-fdivs=255/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mcustom-fadds=253/mcustom-fdivs=255/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mcustom-fadds=253/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mcustom-fadds=253/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mcustom-fdivs=255/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mcustom-fdivs=255/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mul/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mulx/mhw-div/mcustom-fadds=253/mcustom-fdivs=255/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mulx/mhw-div/mcustom-fadds=253/mcustom-fdivs=255/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mulx/mhw-div/mcustom-fadds=253/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mulx/mhw-div/mcustom-fadds=253/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mulx/mhw-div/mcustom-fdivs=255/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mulx/mhw-div/mcustom-fdivs=255/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mulx/mhw-div/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mulx/mhw-div/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mulx/mcustom-fadds=253/mcustom-fdivs=255/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mulx/mcustom-fadds=253/mcustom-fdivs=255/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mulx/mcustom-fadds=253/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mulx/mcustom-fadds=253/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mulx/mcustom-fdivs=255/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mulx/mcustom-fdivs=255/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mulx/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-mulx/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-div/mcustom-fadds=253/mcustom-fdivs=255/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-div/mcustom-fadds=253/mcustom-fdivs=255/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-div/mcustom-fadds=253/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-div/mcustom-fadds=253/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-div/mcustom-fdivs=255/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-div/mcustom-fdivs=255/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-div/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mhw-div/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mcustom-fadds=253/mcustom-fdivs=255/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mcustom-fadds=253/mcustom-fdivs=255/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mcustom-fadds=253/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mcustom-fadds=253/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mcustom-fdivs=255/mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mcustom-fdivs=255/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mcustom-fmuls=252/mcustom-fsubs=254
+MULTILIB_EXCEPTIONS += mcustom-fsubs=254
1.9.3
