Executing Thread Migrating Due to Affinity Change
Sebastian Huber
Mon Jun 2 07:57:38 UTC 2014
On 2014-05-30 17:41, Joel Sherrill wrote:
>>> I suppose I should have posted the patch for review by now but I was hoping
>>> >>to have it completely working with tests when posted. Anyway, it is
>>> >>attached. The key is that I modified the priority SMP to let
>>> >>let get_lowest_scheduled() and get_highest_ready() both be passed in
>>> >>from higher levels.
>>> >>The selection of get_lowest_scheduled() and get_highest_ready()
>>> >>include the option of a filter thread. The filter thread is used
>>> >>as to check that the victim's CPU is in the potential heir's affinity
>>> >>set.
>> >Looks good, apart from the extra NULL pointer check.
> The NULL is used in one case. Which NULL check are you referring to?
> _Scheduler_priority_affinity_SMP_Get_lowest_scheduled() can return
> NULL if based on the affinity of the thread being considered, it shouldn't
> replace any of the scheduled threads.
> NULL indicates nothing to do.
See below.
>>> >>I think the logic works out so that the normal calls to
>>> >>_Scheduler_SMP_Allocate_processor() have selected the
>>> >>correct thread/CPU.
>>> >>I don't see the extra logic in _Scheduler_SMP_Allocate_processor()
>>> >>having a negative impact. What do you see that I might be missing?
>> >The current _Scheduler_SMP_Allocate_processor() tries to keep a thread
>> >on its executing processor. The thread dispatch is asynchronous on
>> >SMP. So for example if you block/unblock a thread extremely fast, then
>> >this helps to avoid a thread migration. I think this optimization
>> >conflicts with the affinity scheduler.
> Does your _Scheduler_SMP_Allocate_processor_exact() address this? If so,
> how?
>>>>> >>>>static inline void _Scheduler_SMP_Allocate_processor_exact(
>>>>> >>>> Scheduler_SMP_Context *self,
>>>>> >>>> Thread_Control *scheduled,
>>>>> >>>> Thread_Control *victim
>>>>> >>>> Scheduler_SMP_Node *scheduled_node = _Scheduler_SMP_Node_get(
>>>>> >>>>scheduled );
>>>>> >>>> Per_CPU_Control *cpu_of_scheduled = _Thread_Get_CPU( scheduled );
>>>>> >>>> Per_CPU_Control *cpu_of_victim = _Thread_Get_CPU( victim );
>>>>> >>>> Per_CPU_Control *cpu_self = _Per_CPU_Get();
>>>>> >>>> _Scheduler_SMP_Node_change_state(
>>>>> >>>> scheduled_node,
>>>>> >>>> SCHEDULER_SMP_NODE_SCHEDULED
>>>>> >>>> _Thread_Set_CPU( scheduled, cpu_of_victim );
>>>>> >>>> _Scheduler_SMP_Update_heir( cpu_self, cpu_of_victim, scheduled );
>>>>> >>>>You can even use this function to do things like this:
>>>>> >>>>_Scheduler_SMP_Allocate_processor_exact(self, executing, other);
>>>>> >>>>_Scheduler_SMP_Allocate_processor_exact(self, other, executing);
>>>>> >>>>This works because the is executing indicator moved to the thread
>>>>> >>>>context and is maintained at the lowest context switch level. For
>>>>> >>>>proper migration the scheduler must ensure that,
>>>>> >>>>1. an heir thread other than the migrating thread exists on the source
>>>>> >>>>processor, and
>>>>> >>>>2. the migrating thread is the heir thread on the destination processor.
>>> >>Hmmm... If I am using the normal _Scheduler_SMP_Allocate_processor()
>>> >>aren't these ensured?
>> >Yes, it is ensured, but you can probably not use this function for your
>> >affinity scheduler due to the _Scheduler_SMP_Is_processor_owned_by_us(
>> >self, cpu_of_scheduled ) check.
> Ahh... let me think about this over the weekend.
> Would you mind if _Scheduler_SMP_Allocate_processor() went from inline
> to a passed in method? Otherwise, I think there will be a lot of
> duplication.
> This would seem to be in keeping with the current style.
One more function pointer shouldn't be a big problem.
>>> >>-- Joel Sherrill, Ph.D. Director of Research & Development
>>> >>joel.sherrill at OARcorp.com On-Line Applications Research Ask me about
>>> >>RTEMS: a free RTOS Huntsville AL 35805 Support Available (256) 722-9985
>>> >>0004-Add-SMP-Priority-Scheduler-with-Affinity.patch
>>> >>>From d83641f11d016a2cd73e2661326a5dc873ba0c3c Mon Sep 17 00:00:00 2001
>>> >>From: Joel Sherrill<joel.sherrill at oarcorp.com>
>>> >>Date: Mon, 19 May 2014 15:26:55 -0500
>>> >>Subject: [PATCH 4/4] Add SMP Priority Scheduler with Affinity
>>> >>Added Thread_Control * parameter to Scheduler_SMP_Get_highest_ready type
>>> >>so methods looking for the highest ready thread can filter by the processor
>>> >>on which the thread blocking resides. This allows affinity to be considered.
>>> >>Simple Priority SMP and Priority SMP ignore this parameter.
>>> >>This scheduler attempts to account for needed thread migrations.
>>> >>==Side Effects of Adding This Scheduler==
>>> >>+ Added get_lowest_scheduled to _Scheduler_SMP_Enqueue_ordered().
>>> >>+ schedulerprioritysmpimpl.h is a new file with prototypes for methods
>>> >> which were formerly static in schedulerprioritysmp.c but now need to
>>> >> be public to be shared with this scheduler.
>>> >>NOTE:
>>> >> _Scheduler_SMP_Get_lowest_ready() appears to have a path which would
>>> >> allow it to return a NULL. Previously, _Scheduler_SMP_Enqueue_ordered()
>>> >> would have asserted on it. If it cannot return a NULL,
>>> >> _Scheduler_SMP_Get_lowest_ready() should have an assertions.
>>> >>@@ -448,6 +464,8 @@ static inline Thread_Control *_Scheduler_SMP_Get_lowest_scheduled(
>>> >> * scheduled nodes.
>>> >> * @param[in] move_from_scheduled_to_ready Function to move a node from the set
>>> >> * of scheduled nodes to the set of ready nodes.
>>> >>+ * @param[in] get_lowest_scheduled Function to select the thread from the
>>> >>+ * scheduled nodes to replace. It may not be possible to find one.
>>> >> static inline void _Scheduler_SMP_Enqueue_ordered(
>>> >> Scheduler_Context *context,
>>> >>@@ -455,16 +473,28 @@ static inline void _Scheduler_SMP_Enqueue_ordered(
>>> >> Chain_Node_order order,
>>> >> Scheduler_SMP_Insert insert_ready,
>>> >> Scheduler_SMP_Insert insert_scheduled,
>>> >>- Scheduler_SMP_Move move_from_scheduled_to_ready
>>> >>+ Scheduler_SMP_Move move_from_scheduled_to_ready,
>>> >>+ Scheduler_SMP_Get_lowest_scheduled get_lowest_scheduled
>>> >> Scheduler_SMP_Context *self = _Scheduler_SMP_Get_self( context );
>>> >> Thread_Control *lowest_scheduled =
>>> >>- _Scheduler_SMP_Get_lowest_scheduled( self );
>>> >>- _Assert( lowest_scheduled != NULL );
>>> >>+ ( *get_lowest_scheduled )( context, thread, order );
>>> >>- if ( ( *order )( &thread->Object.Node, &lowest_scheduled->Object.Node ) ) {
>>> >>+ * get_lowest_scheduled can return a NULL if no scheduled threads
>>> >>+ * should be removed from their processor based on the selection
>>> >>+ * criteria. For example, this can occur when the affinity of the
>>> >>+ * thread being enqueued schedules it against higher priority threads.
>>> >>+ * A low priority thread with affinity can only consider the threads
>>> >>+ * which are on the cores if has affinity for.
>>> >>+ * The get_lowest_scheduled helper should assert on not returning NULL
>>> >>+ * if that is not possible for that scheduler.
>>> >>+ if ( lowest_scheduled &&
>>> >>+ ( *order )( &thread->Object.Node, &lowest_scheduled->Object.Node ) ) {
>>> >> Scheduler_SMP_Node *lowest_scheduled_node =
>>> >> _Scheduler_SMP_Node_get( lowest_scheduled );
>> >I think its possible to avoid the extra NULL pointer check here, if you
>> >use a special order function that returns false if the second parameter
>> >is NULL. The problem is that this adds untestable code for the normal
>> >SMP schedulers.
See last comment regarding the NULL pointer check. You can use something like
this to move the NULL pointer check to a scheduler variant specific function:
RTEMS_INLINE_ROUTINE bool
_Scheduler_priority_affinity_SMP_Insert_priority_lifo_order(
const Chain_Node *to_insert,
const Chain_Node *next
const Thread_Control *thread_to_insert = (const Thread_Control *) to_insert;
const Thread_Control *thread_next = (const Thread_Control *) next;
return thread_next != NULL
&& thread_to_insert->current_priority <= thread_next->current_priority;
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
