[PATCH 4/4] score: Use Resource Handler for MrsP semaphores
Sebastian Huber
Mon Jun 2 08:31:57 UTC 2014
On 2014-05-28 23:45, Gedare Bloom wrote:
>> @@ -200,27 +250,36 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Obtain(
>> > MRSP_Status status;
>> > const Scheduler_Control *scheduler = _Scheduler_Get( executing );
>> > uint32_t scheduler_index = _Scheduler_Get_index( scheduler );
>> >+ Priority_Control initial_priority = executing->current_priority;
>> > Priority_Control ceiling_priority =
>> > _MRSP_Get_ceiling_priority( mrsp, scheduler_index );
>> > bool priority_ok = !_Scheduler_Is_priority_higher_than(
>> > scheduler,
>> >- executing->current_priority,
>> >+ initial_priority,
>> > ceiling_priority
>> >+ Resource_Node *owner = _Resource_Get_owner( &mrsp->Resource );
> I'd put this after the priority_ok check, for better readability by
> keeping the error check closer to the cause. (Ahem, this should
> probably be in our conventions too, eh?)
This change would affect code generation and would make it less efficient. The
_Scheduler_Is_priority_higher_than() calls a global function and thus owner
would have to be saved/restored around this call.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
