[PATCH 2/5] SPARC: add BSP specific error handler
Daniel Hellstrom daniel at gaisler.com
Wed Jun 4 18:48:00 UTC 2014
On 06/04/2014 11:51 AM, Sebastian Huber wrote:
> On 2014-06-04 11:23, Daniel Hellstrom wrote:
>> Instead of calling the system call TA instruction directly it
>> is better paractise to isolate the trap implementation to the
>> system call functions.
>> The BSP_fatal_return() should always exist, regardless of SPARC
>> CPU.
> Why do we need BSP_fatal_return() and bsp_reset()?
The LEON3 doesn't, it does not define bsp_reset. I tried to preserve the
behaviour of LEON2 and ERC32 BSPs, the bsp_reset is called from the
fatal handler. On all SPARC BSPs, ending up in BSP_fatal_return is a
result of bootcard or bsp_start_on_secondary_processor returning which
they should never do. The two functions also have different error exit
codes.
