[PATCH 2/5] SPARC: add BSP specific error handler
Thu Jun 5 14:54:30 UTC 2014
On 2014-06-04 20:48, Daniel Hellstrom wrote:
> On 06/04/2014 11:51 AM, Sebastian Huber wrote:
>> On 2014-06-04 11:23, Daniel Hellstrom wrote:
>>> Instead of calling the system call TA instruction directly it
>>> is better paractise to isolate the trap implementation to the
>>> system call functions.
>>> The BSP_fatal_return() should always exist, regardless of SPARC
>>> CPU.
>> Why do we need BSP_fatal_return() and bsp_reset()?
> The LEON3 doesn't, it does not define bsp_reset. I tried to preserve the
> behaviour of LEON2 and ERC32 BSPs, the bsp_reset is called from the fatal
> handler. On all SPARC BSPs, ending up in BSP_fatal_return is a result of
> bootcard or bsp_start_on_secondary_processor returning which they should never
> do. The two functions also have different error exit codes.
Ok, so this BSP_fatal_return() is used to mark unreachable code.  Maybe we
should just remove these two special cases since its impossible to test this
code or we could also add a general _Unreachable_code() function.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
