[PATCH 3/3] smpschedsem01: New test Test to verify task priority is inherited from a semaphore.
Thu Jun 12 13:06:45 UTC 2014
On 2014-06-11 21:18, jennifer wrote:
> +++ b/testsuites/smptests/smpschedsem01/smpschedsem01.doc
> @@ -0,0 +1,11 @@
> +This file describes the directives and concepts tested by this test set.
> +test set name: smpschedaffinity01
> +directives:
> +  - XXX
> +concepts:
> +  - Ensure that affinity is honored at task start.
This file doesn't match with the subject.  What is the purpose of this test?
If you want to test the change priority operation, then you may have a look at:
http://git.rtems.org/rtems/tree/testsuites/smptests/smpscheduler03/init.c
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
