[PATCH 3/3] smpschedsem01: New test Test to verify task priority is inherited from a semaphore.
Jennifer Averett Jennifer.Averett at OARcorp.com
Thu Jun 12 13:11:48 UTC 2014
The test verifies that when you start a task with affinity of core X
it runs on core X.  It's a c version of one of the scenarios that test
the affinity scheduler.
> -----Original Message-----
> From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
> Sent: Thursday, June 12, 2014 8:07 AM
> To: Jennifer Averett
> Cc: rtems-devel at rtems.org
> Subject: Re: [PATCH 3/3] smpschedsem01: New test Test to verify task
> On 2014-06-11 21:18, jennifer wrote:
> > +++ b/testsuites/smptests/smpschedsem01/smpschedsem01.doc
> > @@ -0,0 +1,11 @@
> > +This file describes the directives and concepts tested by this test set.
> > +test set name: smpschedaffinity01
> > +directives:
> > +  - XXX
> > +concepts:
> > +  - Ensure that affinity is honored at task start.
> This file doesn't match with the subject.  What is the purpose of this test?
> If you want to test the change priority operation, then you may have a look
> at:
> http://git.rtems.org/rtems/tree/testsuites/smptests/smpscheduler03/init.c
