[PATCH 3/3] smpschedsem01: New test Test to verify task priority is inherited from a semaphore.
Jennifer Averett Jennifer.Averett at OARcorp.com
Thu Jun 12 13:43:16 UTC 2014
All the *.doc and *.scn are incorrect.  They will be updated to match
the tests.
> -----Original Message-----
> From: Jennifer Averett
> Sent: Thursday, June 12, 2014 8:15 AM
> To: Jennifer Averett; Sebastian Huber
> Cc: rtems-devel at rtems.org
> Subject: RE: [PATCH 3/3] smpschedsem01: New test Test to verify task
> Sorry looking at the wrong  test.  This test is one that Joel asked me to add for
> each
> Schedulers that just verifies that priority is inherited from a higher priority
> semaphore
> when it is obtained.  I thought I had fixed the doc files for the tests but must
> have
> missed this one.
> > From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Jennifer
> > Averett
> > Sent: Thursday, June 12, 2014 8:12 AM
> > To: Sebastian Huber
> > The test verifies that when you start a task with affinity of core X it runs on
> > core X.  It's a c version of one of the scenarios that test the affinity
> scheduler.
> > > From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
> > > Sent: Thursday, June 12, 2014 8:07 AM
> > > Subject: Re: [PATCH 3/3] smpschedsem01: New test Test to verify task
> > > On 2014-06-11 21:18, jennifer wrote:
> > > > +++ b/testsuites/smptests/smpschedsem01/smpschedsem01.doc
> > > > @@ -0,0 +1,11 @@
> > > > +This file describes the directives and concepts tested by this test set.
> > > > +test set name: smpschedaffinity01
> > > > +directives:
> > > > +  - XXX
> > > > +concepts:
> > > > +  - Ensure that affinity is honored at task start.
> > > This file doesn't match with the subject.  What is the purpose of this test?
> > > If you want to test the change priority operation, then you may have a
> > > look
> > > at:
> http://git.rtems.org/rtems/tree/testsuites/smptests/smpscheduler03/ini
> > > t.c
> > > Sebastian Huber, embedded brains GmbH
> > > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > > Phone   : +49 89 189 47 41-16
> > > Fax     : +49 89 189 47 41-09
> > > E-Mail  : sebastian.huber at embedded-brains.de
> > > PGP     : Public key available on request.
> > > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > devel mailing list
> > devel at rtems.org
