[PATCH 3/3] smpschedsem01: New test Test to verify task priority is inherited from a semaphore.
Jennifer Averett Jennifer.Averett at OARcorp.com
Thu Jun 12 13:15:02 UTC 2014
Sorry looking at the wrong  test.  This test is one that Joel asked me to add for each
Schedulers that just verifies that priority is inherited from a higher priority semaphore
when it is obtained.  I thought I had fixed the doc files for the tests but must have
missed this one.
> -----Original Message-----
> From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Jennifer
> Averett
> Sent: Thursday, June 12, 2014 8:12 AM
> To: Sebastian Huber
> Cc: rtems-devel at rtems.org
> Subject: RE: [PATCH 3/3] smpschedsem01: New test Test to verify task
> The test verifies that when you start a task with affinity of core X it runs on
> core X.  It's a c version of one of the scenarios that test the affinity scheduler.
> > From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
> > Sent: Thursday, June 12, 2014 8:07 AM
> > To: Jennifer Averett
> > Subject: Re: [PATCH 3/3] smpschedsem01: New test Test to verify task
> > On 2014-06-11 21:18, jennifer wrote:
> > > +++ b/testsuites/smptests/smpschedsem01/smpschedsem01.doc
> > > @@ -0,0 +1,11 @@
> > > +This file describes the directives and concepts tested by this test set.
> > > +test set name: smpschedaffinity01
> > > +directives:
> > > +  - XXX
> > > +concepts:
> > > +  - Ensure that affinity is honored at task start.
> > This file doesn't match with the subject.  What is the purpose of this test?
> > If you want to test the change priority operation, then you may have a
> > look
> > at:
> > http://git.rtems.org/rtems/tree/testsuites/smptests/smpscheduler03/ini
> > t.c
> > Sebastian Huber, embedded brains GmbH
> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > Phone   : +49 89 189 47 41-16
> > Fax     : +49 89 189 47 41-09
> > E-Mail  : sebastian.huber at embedded-brains.de
> > PGP     : Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> devel mailing list
> devel at rtems.org
