Rtems-test with qemu integration for pc386
Thu Jun 26 21:26:50 UTC 2014
On 27/06/2014 4:09 am, Joel Sherrill wrote:
> See pc386/configure.ac for this
> RTEMS_BSP_CLEANUP_OPTIONS(1, 1)
> dnl    argument 1 indicates the default value for BSP_PRESS_KEY_FOR_RESET
> dnl    argument 2 indicates the default value for BSP_RESET_BOARD_AT_EXIT
> Sounds like the default should change or the test build needs to pass
> in BSP_PRESS_KEY_FOR_RESET=0.
Yes please or even remove this code from the BSP. It is not a good thing
to have in an embedded system. This is system and app level type
functionality.
