Rtems-test with qemu integration for pc386
Fri Jun 27 01:34:22 UTC 2014
On Thu, Jun 26, 2014 at 5:26 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 27/06/2014 4:09 am, Joel Sherrill wrote:
>> See pc386/configure.ac for this
>> RTEMS_BSP_CLEANUP_OPTIONS(1, 1)
>> dnl    argument 1 indicates the default value for BSP_PRESS_KEY_FOR_RESET
>> dnl    argument 2 indicates the default value for BSP_RESET_BOARD_AT_EXIT
>> Sounds like the default should change or the test build needs to pass
>> in BSP_PRESS_KEY_FOR_RESET=0.
> Yes please or even remove this code from the BSP. It is not a good thing to
> have in an embedded system. This is system and app level type functionality.
+1
> Chris
> devel mailing list
> devel at rtems.org
