[rtems commit] m68k/shared/misc/memProbe.c: Add prototype to eliminate warning
    Joel Sherrill
    Joel.Sherrill at OARcorp.com
    Mon Jun  2 01:24:35 UTC 2014
On Jun 1, 2014 8:00 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Sun, Jun 1, 2014 at 7:10 PM, Joel Sherrill <joel at rtems.org> wrote:
> > Module:    rtems
> > Branch:    master
> > Commit:    6ddc4dab2085e9db28b2470f05aaa54652d68a84
> > Changeset: http://git.rtems.org/rtems/commit/?id=6ddc4dab2085e9db28b2470f05aaa54652d68a84
> > Author:    Joel Sherrill <joel.sherrill at oarcorp.com>
> > Date:      Sun Jun  1 18:18:00 2014 -0500
> >  c/src/lib/libcpu/m68k/shared/misc/memProbe.c |    2 ++
> >  1 files changed, 2 insertions(+), 0 deletions(-)
> > diff --git a/c/src/lib/libcpu/m68k/shared/misc/memProbe.c b/c/src/lib/libcpu/m68k/shared/misc/memProbe.c
> > index 5c52911..d352f76 100644
> > --- a/c/src/lib/libcpu/m68k/shared/misc/memProbe.c
> > +++ b/c/src/lib/libcpu/m68k/shared/misc/memProbe.c
> > @@ -4,6 +4,7 @@
> >  #include <bsp.h>
> >  #include <string.h>
> > +#include <rtems/m68k/sim.h>
> >  #if (M68K_COLDFIRE_ARCH == 1)
> >  # define EXCEPTION_FRAME_PC_OFFSET "4"
> > @@ -16,6 +17,7 @@ int memProbeByte(void *from, void *to);
> >  int memProbeShort(void *from, void *to);
> >  int memProbeLong(void *from, void *to);
> >  int memProbeCatcher(void);
> > +rtems_status_code bspExtMemProbe(void *addr, int write, int size, void *pval);
> We should generally prefer to declare functions in a header file, or
> make them static if not exported.
Got a suggestion? Did I miss an existing prototype?
> >  __asm__(
> >      ".text\n"
> > rtems-vc mailing list
> > rtems-vc at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-vc
> rtems-devel mailing list
> rtems-devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140601/431e2b31/attachment-0001.html>
