[rtems commit] m68k/shared/misc/memProbe.c: Add prototype to eliminate warning
Mon Jun 2 01:02:31 UTC 2014
On Sun, Jun 1, 2014 at 7:10 PM, Joel Sherrill <joel at rtems.org> wrote:
> Module:    rtems
> Branch:    master
> Commit:    6ddc4dab2085e9db28b2470f05aaa54652d68a84
> Changeset: http://git.rtems.org/rtems/commit/?id=6ddc4dab2085e9db28b2470f05aaa54652d68a84
> Author:    Joel Sherrill <joel.sherrill at oarcorp.com>
> Date:      Sun Jun  1 18:18:00 2014 -0500
>  c/src/lib/libcpu/m68k/shared/misc/memProbe.c |    2 ++
>  1 files changed, 2 insertions(+), 0 deletions(-)
> diff --git a/c/src/lib/libcpu/m68k/shared/misc/memProbe.c b/c/src/lib/libcpu/m68k/shared/misc/memProbe.c
> index 5c52911..d352f76 100644
> --- a/c/src/lib/libcpu/m68k/shared/misc/memProbe.c
> +++ b/c/src/lib/libcpu/m68k/shared/misc/memProbe.c
> @@ -4,6 +4,7 @@
>  #include <bsp.h>
>  #include <string.h>
> +#include <rtems/m68k/sim.h>
>  #if (M68K_COLDFIRE_ARCH == 1)
>  # define EXCEPTION_FRAME_PC_OFFSET "4"
> @@ -16,6 +17,7 @@ int memProbeByte(void *from, void *to);
>  int memProbeShort(void *from, void *to);
>  int memProbeLong(void *from, void *to);
>  int memProbeCatcher(void);
> +rtems_status_code bspExtMemProbe(void *addr, int write, int size, void *pval);
We should generally prefer to declare functions in a header file, or
make them static if not exported.
>  __asm__(
>      ".text\n"
> rtems-vc mailing list
> rtems-vc at rtems.org
> http://www.rtems.org/mailman/listinfo/rtems-vc
