[PATCH 4/4] score: Use Resource Handler for MrsP semaphores
Gedare Bloom
gedare at rtems.org
Mon Jun 2 13:17:07 UTC 2014
>> @@ -200,27 +250,36 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Obtain(
>> MRSP_Status status;
>> const Scheduler_Control *scheduler = _Scheduler_Get( executing );
>> uint32_t scheduler_index = _Scheduler_Get_index( scheduler );
>> + Priority_Control initial_priority = executing->current_priority;
>> Priority_Control ceiling_priority =
>> _MRSP_Get_ceiling_priority( mrsp, scheduler_index );
>> bool priority_ok = !_Scheduler_Is_priority_higher_than(
>> scheduler,
>> - executing->current_priority,
>> + initial_priority,
>> ceiling_priority
>> + Resource_Node *owner = _Resource_Get_owner( &mrsp->Resource );
> I'd put this after the priority_ok check, for better readability by
> keeping the error check closer to the cause. (Ahem, this should
> probably be in our conventions too, eh?)
>> if ( !priority_ok) {
>> return MRSP_INVALID_PRIORITY;
I guess I wasn't clear, I meant you should do owner =
_Resource_Get_owner() here. e.g.
Resource_Node *owner;
scheduler,
initial_priority,
ceiling_priority
Also, at one point in time we discussed about a rule of not having
function calls in variable initialization. I will look if that is an
actual convention or not, but it would make this code easier to read.
-Gedare
