[PATCH 1/4] score: Add Resource Handler
Gedare Bloom
gedare at rtems.org
Mon Jun 2 13:47:24 UTC 2014
On Mon, Jun 2, 2014 at 4:35 AM, Sebastian Huber
> On 2014-05-28 23:48, Gedare Bloom wrote:
>>> >+ * @brief Returns true if this is the most recent resource of the node,
>>> > and
>>> >+ * false otherwise.
>>> >+ * Resources are organized in last in first out order (LIFO).
>>> >+ * @param[in] node The node containing the resource.
>>> >+ * @param[in] resource The resource in question.
>>> >+RTEMS_INLINE_ROUTINE bool _Resource_Is_most_recent_resource_of_node(
>>> >+ const Resource_Node *node,
>>> >+ const Resource_Control *resource
>> At first this function name confused me when I saw it used. I'm not
>> sure if a better name exists but it may be worth considering. Also,
>> this whole Resource handler is a bit odd compared to other data
>> structures in RTEMS, in that the interface functions take a Node first
>> and a Control second. Usually the Control comes first.
> The first parameter is usually the this object. So for the
> _Resource_Node_*() functions this is a node. The term "recent" implies
> temporal order and thus is well defined. If we use "first", "last", "top"
> or whatever then we would have to explicitly specify the order which makes
> the name even longer.
OK. Is _Resource_Is_most_recently_used() ok? This has a clear parallel
with well-known language like LRU.
-Gedare
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
