[PATCH 1/4] score: Add Resource Handler
    Sebastian Huber
    Mon Jun  2 13:50:16 UTC 2014
On 2014-06-02 15:47, Gedare Bloom wrote:
> On Mon, Jun 2, 2014 at 4:35 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de>  wrote:
>> >On 2014-05-28 23:48, Gedare Bloom wrote:
>>>>> >>> >+ * @brief Returns true if this is the most recent resource of the node,
>>>>> >>> >and
>>>>> >>> >+ * false otherwise.
>>>>> >>> >+ * Resources are organized in last in first out order (LIFO).
>>>>> >>> >+ * @param[in] node The node containing the resource.
>>>>> >>> >+ * @param[in] resource The resource in question.
>>>>> >>> >+RTEMS_INLINE_ROUTINE bool _Resource_Is_most_recent_resource_of_node(
>>>>> >>> >+  const Resource_Node    *node,
>>>>> >>> >+  const Resource_Control *resource
>>> >>At first this function name confused me when I saw it used. I'm not
>>> >>sure if a better name exists but it may be worth considering. Also,
>>> >>this whole Resource handler is a bit odd compared to other data
>>> >>structures in RTEMS, in that the interface functions take a Node first
>>> >>and a Control second. Usually the Control comes first.
>> >The first parameter is usually the this object.  So for the
>> >_Resource_Node_*() functions this is a node.  The term "recent" implies
>> >temporal order and thus is well defined.  If we use "first", "last", "top"
>> >or whatever then we would have to explicitly specify the order which makes
>> >the name even longer.
> OK. Is _Resource_Is_most_recently_used() ok? This has a clear parallel
> with well-known language like LRU.
What about _Resource_Is_most_recently_obtained()?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
