[PATCH] LEON2: enable exception prinout by default
Daniel Hellstrom daniel at gaisler.com
Mon Jun 2 16:02:05 UTC 2014
 c/src/lib/libbsp/sparc/leon2/configure.ac |    2 +-
 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon2/configure.ac b/c/src/lib/libbsp/sparc/leon2/configure.ac
index 6c7e25d..610a049 100644
--- a/c/src/lib/libbsp/sparc/leon2/configure.ac
+++ b/c/src/lib/libbsp/sparc/leon2/configure.ac
@@ -36,7 +36,7 @@ RTEMS_BSPOPTS_HELP([SIMSPARC_FAST_IDLE],
  time spent in the idle task is minimized.  This significantly reduces
  the wall time required to execute the RTEMS test suites.])
-RTEMS_BSP_CLEANUP_OPTIONS(0, 1)
+RTEMS_BSP_CLEANUP_OPTIONS(0, 1, 1)
 # Explicitly list all Makefiles here
 AC_CONFIG_FILES([Makefile])
1.7.0.4
