[PATCH 2/2] score: Rename _Scheduler_Update()
Tue Jun 3 15:13:13 UTC 2014
Both patches look good to me.
On Tue, Jun 3, 2014 at 10:31 AM, Sebastian Huber
> Rename _Scheduler_Update() to _Scheduler_Update_priority().  Add
> parameter for the new thread priority to avoid direct usage of
> Thread_Control::current_priority in the scheduler operation.
>  cpukit/score/include/rtems/score/scheduler.h       |   14 ++++++++++----
>  cpukit/score/include/rtems/score/schedulercbs.h    |    2 +-
>  cpukit/score/include/rtems/score/scheduleredf.h    |    7 ++++---
>  cpukit/score/include/rtems/score/schedulerimpl.h   |   20 +++++++++++++++-----
>  .../score/include/rtems/score/schedulerpriority.h  |   15 ++++++---------
>  .../rtems/score/schedulerpriorityaffinitysmp.h     |    2 +-
>  .../include/rtems/score/schedulerprioritysmp.h     |    7 ++++---
>  cpukit/score/include/rtems/score/schedulersimple.h |    2 +-
>  .../score/include/rtems/score/schedulersimplesmp.h |    2 +-
>  cpukit/score/src/schedulerdefaultupdate.c          |   10 ++++++----
>  cpukit/score/src/scheduleredfupdate.c              |    6 ++++--
>  cpukit/score/src/schedulerprioritysmp.c            |    7 ++++---
>  cpukit/score/src/schedulerpriorityupdate.c         |    7 ++++---
>  cpukit/score/src/threadchangepriority.c            |    2 +-
>  cpukit/score/src/threadsetpriority.c               |    6 +++++-
>  15 files changed, 67 insertions(+), 42 deletions(-)
> diff --git a/cpukit/score/include/rtems/score/scheduler.h b/cpukit/score/include/rtems/score/scheduler.h
> index 7ca2133..542e4ae 100644
> --- a/cpukit/score/include/rtems/score/scheduler.h
> +++ b/cpukit/score/include/rtems/score/scheduler.h
> @@ -77,8 +77,12 @@ typedef struct {
>    /** @see _Scheduler_Node_destroy() */
>    void ( *node_destroy )( const Scheduler_Control *, Thread_Control * );
> -  /** @see _Scheduler_Update() */
> -  void ( *update )( const Scheduler_Control *, Thread_Control * );
> +  /** @see _Scheduler_Update_priority() */
> +  void ( *update_priority )(
> +    const Scheduler_Control *,
> +    Thread_Control *,
> +    Priority_Control
>    /** @see _Scheduler_Priority_compare() */
>    int ( *priority_compare )(
> @@ -277,10 +281,12 @@ void _Scheduler_default_Node_destroy(
>   * @param[in] scheduler Unused.
>   * @param[in] the_thread Unused.
> + * @param[in] new_priority Unused.
> -void _Scheduler_default_Update(
> +void _Scheduler_default_Update_priority(
>    const Scheduler_Control *scheduler,
> -  Thread_Control          *the_thread
> +  Thread_Control          *the_thread,
> +  Priority_Control         new_priority
> diff --git a/cpukit/score/include/rtems/score/schedulercbs.h b/cpukit/score/include/rtems/score/schedulercbs.h
> index 23e528d..473d6fe 100644
> --- a/cpukit/score/include/rtems/score/schedulercbs.h
> +++ b/cpukit/score/include/rtems/score/schedulercbs.h
> @@ -55,7 +55,7 @@ extern "C" {
>      _Scheduler_EDF_Change_priority,  /* change priority entry point */ \
>      _Scheduler_CBS_Node_initialize,  /* node initialize entry point */ \
>      _Scheduler_default_Node_destroy, /* node destroy entry point */ \
> -    _Scheduler_EDF_Update,           /* update entry point */ \
> +    _Scheduler_EDF_Update_priority,  /* update priority entry point */ \
>      _Scheduler_EDF_Priority_compare, /* compares two priorities */ \
>      _Scheduler_CBS_Release_job,      /* new period of task */ \
>      _Scheduler_default_Tick,         /* tick entry point */ \
> diff --git a/cpukit/score/include/rtems/score/scheduleredf.h b/cpukit/score/include/rtems/score/scheduleredf.h
> index a7ed88d..7a20b5b 100644
> --- a/cpukit/score/include/rtems/score/scheduleredf.h
> +++ b/cpukit/score/include/rtems/score/scheduleredf.h
> @@ -48,7 +48,7 @@ extern "C" {
>      _Scheduler_EDF_Node_initialize,  /* node initialize entry point */ \
>      _Scheduler_EDF_Release_job,      /* new period of task */ \
> @@ -161,9 +161,10 @@ void _Scheduler_EDF_Node_initialize(
>   *  @param[in] the_thread will have its scheduler specific information
>   *             structure updated.
> -void _Scheduler_EDF_Update(
> +void _Scheduler_EDF_Update_priority(
> diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
> index 5e7c928..1216f6c 100644
> --- a/cpukit/score/include/rtems/score/schedulerimpl.h
> +++ b/cpukit/score/include/rtems/score/schedulerimpl.h
> @@ -209,16 +209,22 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Node_destroy(
> - * @brief Scheduler update.
> + * @brief Updates the scheduler about a priority change of a not ready thread.
> - * This routine updates @a the_thread->scheduler
> + * @param[in] the_thread The thread.
> + * @param[in] new_priority The new priority of the thread.
> -RTEMS_INLINE_ROUTINE void _Scheduler_Update(
> +RTEMS_INLINE_ROUTINE void _Scheduler_Update_priority(
> -  ( *scheduler->Operations.update )( scheduler, the_thread );
> +  ( *scheduler->Operations.update_priority )(
> +    scheduler,
> +    the_thread,
> +    new_priority
> @@ -367,7 +373,11 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Set(
>      _Scheduler_Node_destroy( current_scheduler, the_thread );
>      the_thread->scheduler = scheduler;
>      _Scheduler_Node_initialize( scheduler, the_thread );
> -    _Scheduler_Update( scheduler, the_thread );
> +    _Scheduler_Update_priority(
> +      scheduler,
> +      the_thread,
> +      the_thread->current_priority
>      _Thread_Clear_state( the_thread, STATES_MIGRATING );
>  #else
> diff --git a/cpukit/score/include/rtems/score/schedulerpriority.h b/cpukit/score/include/rtems/score/schedulerpriority.h
> index 3f18f54..2e4f3ab 100644
> --- a/cpukit/score/include/rtems/score/schedulerpriority.h
> +++ b/cpukit/score/include/rtems/score/schedulerpriority.h
>      _Scheduler_priority_Change_priority,  /* change priority entry point */ \
>      _Scheduler_default_Node_initialize,   /* node initialize entry point */ \
> -    _Scheduler_priority_Update,           /* update entry point */ \
> +    _Scheduler_priority_Update_priority,  /* update priority entry point */ \
>      _Scheduler_priority_Priority_compare, /* compares two priorities */ \
>      _Scheduler_default_Release_job,       /* new period of task */ \
> @@ -139,16 +139,13 @@ void _Scheduler_priority_Schedule(
> - *  @brief Update the scheduler priority.
> - *  This routine updates @a the_thread->scheduler based on @a the_scheduler
> - *  structures and thread state.
> - *  @param[in] the_thread will have its scheduler specific information
> - *             structure updated.
> + *  @brief Updates the scheduler node to reflect the new priority of the
> + *  thread.
> -void _Scheduler_priority_Update(
> +void _Scheduler_priority_Update_priority(
> diff --git a/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h b/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
> index ab35704..0ba8191 100644
> --- a/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
> +++ b/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
> @@ -57,7 +57,7 @@ extern "C" {
>      _Scheduler_priority_SMP_Change_priority, \
>      _Scheduler_priority_affinity_SMP_Node_initialize, \
>      _Scheduler_default_Node_destroy, \
> -    _Scheduler_priority_SMP_Update, \
> +    _Scheduler_priority_SMP_Update_priority, \
>      _Scheduler_priority_Priority_compare, \
>      _Scheduler_default_Release_job, \
>      _Scheduler_default_Tick, \
> diff --git a/cpukit/score/include/rtems/score/schedulerprioritysmp.h b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
> index c17fcf4..cbb8a58 100644
> --- a/cpukit/score/include/rtems/score/schedulerprioritysmp.h
> +++ b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
> @@ -86,7 +86,7 @@ typedef struct {
>      _Scheduler_priority_SMP_Node_initialize, \
> @@ -119,9 +119,10 @@ void _Scheduler_priority_SMP_Change_priority(
>    bool                     prepend_it
> -void _Scheduler_priority_SMP_Update(
> +void _Scheduler_priority_SMP_Update_priority(
> -  Thread_Control *thread
> +  Thread_Control *thread,
>  void _Scheduler_priority_SMP_Yield(
> diff --git a/cpukit/score/include/rtems/score/schedulersimple.h b/cpukit/score/include/rtems/score/schedulersimple.h
> index 9fc2d31..68ed527 100644
> --- a/cpukit/score/include/rtems/score/schedulersimple.h
> +++ b/cpukit/score/include/rtems/score/schedulersimple.h
> @@ -45,7 +45,7 @@ extern "C" {
>      _Scheduler_simple_Change_priority,    /* change priority entry point */ \
> -    _Scheduler_default_Update,            /* update entry point */ \
> +    _Scheduler_default_Update_priority,   /* update priority entry point */ \
> diff --git a/cpukit/score/include/rtems/score/schedulersimplesmp.h b/cpukit/score/include/rtems/score/schedulersimplesmp.h
> index 6ab1dd2..c0195e0 100644
> --- a/cpukit/score/include/rtems/score/schedulersimplesmp.h
> +++ b/cpukit/score/include/rtems/score/schedulersimplesmp.h
> @@ -67,7 +67,7 @@ typedef struct {
>      _Scheduler_simple_SMP_Change_priority, \
>      _Scheduler_simple_SMP_Node_initialize, \
> -    _Scheduler_default_Update, \
> +    _Scheduler_default_Update_priority, \
> diff --git a/cpukit/score/src/schedulerdefaultupdate.c b/cpukit/score/src/schedulerdefaultupdate.c
> index 28d7e1d..fcdc838 100644
> --- a/cpukit/score/src/schedulerdefaultupdate.c
> +++ b/cpukit/score/src/schedulerdefaultupdate.c
> @@ -21,11 +21,13 @@
>  #include <rtems/score/scheduler.h>
> -  ( void ) scheduler;
> -  ( void ) the_thread;
> +  (void) scheduler;
> +  (void) the_thread;
> +  (void) new_priority;
> diff --git a/cpukit/score/src/scheduleredfupdate.c b/cpukit/score/src/scheduleredfupdate.c
> index 99a3e0e..47e3a70 100644
> --- a/cpukit/score/src/scheduleredfupdate.c
> +++ b/cpukit/score/src/scheduleredfupdate.c
> @@ -20,14 +20,16 @@
>  #include <rtems/score/scheduleredfimpl.h>
>    Scheduler_EDF_Node *node = _Scheduler_EDF_Node_get( the_thread );
>    (void) scheduler;
>    if (node->queue_state == SCHEDULER_EDF_QUEUE_STATE_NEVER_HAS_BEEN) {
>      /* Shifts the priority to the region of background tasks. */
> diff --git a/cpukit/score/src/schedulerprioritysmp.c b/cpukit/score/src/schedulerprioritysmp.c
> index e0ed75c..7915ce6 100644
> --- a/cpukit/score/src/schedulerprioritysmp.c
> +++ b/cpukit/score/src/schedulerprioritysmp.c
> @@ -93,15 +93,16 @@ static void _Scheduler_priority_SMP_Do_update(
>    Scheduler_Context *context = _Scheduler_Get_context( scheduler );
>    Scheduler_Node *node = _Scheduler_Node_get( thread );
> -  _Scheduler_priority_SMP_Do_update( context, node, thread->current_priority );
> +  _Scheduler_priority_SMP_Do_update( context, node, new_priority );
>  static Thread_Control *_Scheduler_priority_SMP_Get_highest_ready(
> diff --git a/cpukit/score/src/schedulerpriorityupdate.c b/cpukit/score/src/schedulerpriorityupdate.c
> index e58a609..3f05439 100644
> --- a/cpukit/score/src/schedulerpriorityupdate.c
> +++ b/cpukit/score/src/schedulerpriorityupdate.c
> @@ -20,9 +20,10 @@
>  #include <rtems/score/schedulerpriorityimpl.h>
>    Scheduler_priority_Context *context =
> @@ -31,7 +32,7 @@ void _Scheduler_priority_Update(
>    _Scheduler_priority_Ready_queue_update(
>      &node->Ready_queue,
> -    the_thread->current_priority,
> +    new_priority,
>      &context->Bit_map,
>      &context->Ready[ 0 ]
> diff --git a/cpukit/score/src/threadchangepriority.c b/cpukit/score/src/threadchangepriority.c
> index 8059ab1..8de6325 100644
> --- a/cpukit/score/src/threadchangepriority.c
> +++ b/cpukit/score/src/threadchangepriority.c
> @@ -106,7 +106,7 @@ void _Thread_Change_priority(
>        scheduler = _Scheduler_Get( the_thread );
>        _Scheduler_Schedule( scheduler, the_thread );
>      } else {
> +      _Scheduler_Update_priority( the_thread, new_priority );
>      _ISR_Enable( level );
> diff --git a/cpukit/score/src/threadsetpriority.c b/cpukit/score/src/threadsetpriority.c
> index e128648..455cf20 100644
> --- a/cpukit/score/src/threadsetpriority.c
> +++ b/cpukit/score/src/threadsetpriority.c
> @@ -28,5 +28,9 @@ void _Thread_Set_priority(
>    the_thread->current_priority = new_priority;
> -  _Scheduler_Update( _Scheduler_Get( the_thread ), the_thread );
> +    _Scheduler_Get( the_thread),
> +    the_thread,
> +    new_priority
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
