[PATCH 1/5] Let CPU/BSP Fatal handler have access to source
Wed Jun 4 09:43:29 UTC 2014
On 2014-06-04 11:23, Daniel Hellstrom wrote:
> Without the source the error code does not say that much.
> Let it be up to the CPU/BSP to determine the error code
> reported on fatal shutdown.
> This patch does not change the current behaviour, just
> adds the option to handle the source of the fatal halt.
This change is all right for me.
If someone finds time for this, we should update the CPU supplement:
http://rtems.org/onlinedocs/doc-current/share/rtems/html/cpu_supplement/Port-Specific-Information-Default-Fatal-Error-Processing.html#Port-Specific-Information-Default-Fatal-Error-Processing
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
