BSP submitting requirements
Marcos Díaz
marcos.diaz at tallertechnologies.com
Wed Jun 4 13:52:41 UTC 2014
Hi, we were running the check_submission script and we were fixing
some issues. but now we are having two problems:
One is that a missing file, for example bsp_interrupt_vector_enable,
which is defined in the shared folder outside our bsp's folder, gives
a warning (only with verbose set), but also sets faults to 1, so, we
think it should be just a warning.
Other is the missing sbrk. Thanks!
On Fri, May 30, 2014 at 12:38 PM, Marcos Díaz
<marcos.diaz at tallertechnologies.com> wrote:
> It doesn't run in any simulator..
> I have another question:
> We are developing a bsp for a board with very little memory (32k) when
> we tried to run tmtest (and others) we encounter that couldnt allocate
> more RAM, and one of the things that we saw we could improve is the
> stack size passed for each task.
> For this there exists the CPU_STACK_MINIMUM_SIZE macro, but
> unfortunately it is defined to 4k for ARM, which is too much for us
> (http://git.rtems.org/rtems/tree/cpukit/score/cpu/arm/rtems/score/cpu.h#n176)
> The question is:
> Can we change this macro like for the m68k boards:
> http://git.rtems.org/rtems/tree/cpukit/score/cpu/m68k/rtems/score/cpu.h#n384
> and
> http://git.rtems.org/rtems/tree/cpukit/score/cpu/m68k/rtems/score/m68k.h#n160
> Is this the correct way to do this?
> Thanks!
> On Fri, May 30, 2014 at 12:33 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> On 5/30/2014 9:51 AM, Marcos Díaz wrote:
>>> thanks to all! We will try to submit it soon!
>> Does the BSP run on any simulator? If so, there are a
>> couple of other things we like to have to aid automated
>> testing.
>> Also there is a new file .tcfg which can list the files
>> which do not link or run with a known/expected
>> failure on your BSP. See
>> libbsp/arm/gdbarmsim/make/custom/arm1136jfs-testsuite.tcfg
>> for an example. This is a great way to ignore tests
>> which do not fit on the target.
>>> On Thu, May 29, 2014 at 5:16 PM, Joel Sherrill
>>>> On 5/29/2014 2:34 PM, Gedare Bloom wrote:
>>>>> On Thu, May 29, 2014 at 3:02 PM, Marcos Díaz
>>>>>> Hi! We are about to submit a BSP but we have some doubts:
>>>>>> In http://www.rtems.org/wiki/index.php/Submitting_a_BSP
>>>>>> there is a point that refers to:
>>>>>> Do all files have a CVS $Id$ in them?
>>>>>> What does this mean?
>>>>> That is outdated and shouldn't be there. There is a script in the
>>>>> rtems-testing.git repository located at merge-helpers/check_submission
>>>>> that may be useful to run. I don't know there is much documentation
>>>>> for it, but you just run it from your bsp directory and it does some
>>>>> checks about what is expected to exist in a bsp.
>>>>>> There is other:
>>>>>> Did you provide a TIMES files with the results of the tmtests?
>>>>>> is there any example of a file like this in order to see how it should be
>>>>> I think this is old too and can be ignored for now, I only see one
>>>>> example in the tree under libbsp/m68k/uC5282/TIMES
>>>> There are more times* files in the tree.
>>>> These are certainly optional but give the next person a good handle on
>>>> what the expected performance is.
>>>>> -Gedare
>>>>>> Thanks!
>>>>>> ______________________________
>>>>>> Marcos Díaz
>>>>>> Software Engineer
>>>>>> San Lorenzo 47, 3rd Floor, Office 5
>>>>>> Córdoba, Argentina
>>>>>> Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
>>>>>> Skype: markdiaz22
>>>>>> _______________________________________________
>>>>>> rtems-devel mailing list
>>>>>> rtems-devel at rtems.org
>>>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>>>> Joel Sherrill, Ph.D. Director of Research & Development
>>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>>> Support Available (256) 722-9985
> Marcos Díaz
> Software Engineer
> Córdoba, Argentina
> Skype: markdiaz22
Marcos Díaz
Software Engineer
Córdoba, Argentina
Skype: markdiaz22
