BSP submitting requirements
Wed Jun 4 14:10:59 UTC 2014
On 6/4/2014 8:52 AM, Marcos Díaz wrote:
> Hi, we were running the check_submission script and we were fixing
> some issues. but now we are having two problems:
The script is far from perfect and the structure of a BSP is a moving
target.
> One is that a missing file, for example bsp_interrupt_vector_enable,
> which is defined in the shared folder outside our bsp's folder, gives
> a warning (only with verbose set), but also sets faults to 1, so, we
> think it should be just a warning.
Can you provide the output and a candidate patch?
> Other is the missing sbrk. Thanks!
A BSP provides its own sbrk(). Most use the default one in libbsp/shared.
Should just be a matter of including in in Makefile.am.
--joel
> On Fri, May 30, 2014 at 12:38 PM, Marcos Díaz
> <marcos.diaz at tallertechnologies.com> wrote:
>> It doesn't run in any simulator..
>> I have another question:
>> We are developing a bsp for a board with very little memory (32k) when
>> we tried to run tmtest (and others) we encounter that couldnt allocate
>> more RAM, and one of the things that we saw we could improve is the
>> stack size passed for each task.
>> For this there exists the CPU_STACK_MINIMUM_SIZE macro, but
>> unfortunately it is defined to 4k for ARM, which is too much for us
>> (http://git.rtems.org/rtems/tree/cpukit/score/cpu/arm/rtems/score/cpu.h#n176)
>> The question is:
>> Can we change this macro like for the m68k boards:
>> http://git.rtems.org/rtems/tree/cpukit/score/cpu/m68k/rtems/score/cpu.h#n384
>> and
>> http://git.rtems.org/rtems/tree/cpukit/score/cpu/m68k/rtems/score/m68k.h#n160
>> Is this the correct way to do this?
>> Thanks!
>> On Fri, May 30, 2014 at 12:33 PM, Joel Sherrill
>> <joel.sherrill at oarcorp.com> wrote:
>>> On 5/30/2014 9:51 AM, Marcos Díaz wrote:
>>>> thanks to all! We will try to submit it soon!
>>> Does the BSP run on any simulator? If so, there are a
>>> couple of other things we like to have to aid automated
>>> testing.
>>> Also there is a new file .tcfg which can list the files
>>> which do not link or run with a known/expected
>>> failure on your BSP.  See
>>> libbsp/arm/gdbarmsim/make/custom/arm1136jfs-testsuite.tcfg
>>> for an example. This is a great way to ignore tests
>>> which do not fit on the target.
>>>> On Thu, May 29, 2014 at 5:16 PM, Joel Sherrill
>>>>> On 5/29/2014 2:34 PM, Gedare Bloom wrote:
>>>>>> On Thu, May 29, 2014 at 3:02 PM, Marcos Díaz
>>>>>>> Hi! We are about to submit a BSP but we have some doubts:
>>>>>>> In http://www.rtems.org/wiki/index.php/Submitting_a_BSP
>>>>>>> there is a point that refers to:
>>>>>>> Do all files have a CVS $Id$ in them?
>>>>>>> What does this mean?
>>>>>> That is outdated and shouldn't be there. There is a script in the
>>>>>> rtems-testing.git repository located at merge-helpers/check_submission
>>>>>> that may be useful to run. I don't know there is much documentation
>>>>>> for it, but you just run it from your bsp directory and it does some
>>>>>> checks about what is expected to exist in a bsp.
>>>>>>> There is other:
>>>>>>> Did you provide a TIMES files with the results of the tmtests?
>>>>>>> is there any example of a file like this in order to see how it should be
>>>>>> I think this is old too and can be ignored for now, I only see one
>>>>>> example in the tree under libbsp/m68k/uC5282/TIMES
>>>>> There are more times* files in the tree.
>>>>> These are certainly optional but give the next person a good handle on
>>>>> what the expected performance is.
>>>>>> -Gedare
>>>>>>> Thanks!
>>>>>>> ______________________________
>>>>>>> Marcos Díaz
>>>>>>> Software Engineer
>>>>>>> San Lorenzo 47, 3rd Floor, Office 5
>>>>>>> Córdoba, Argentina
>>>>>>> Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
>>>>>>> Skype: markdiaz22
>>>>>>> _______________________________________________
>>>>>>> rtems-devel mailing list
>>>>>>> rtems-devel at rtems.org
>>>>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>>>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>>> Support Available                (256) 722-9985
>> Marcos Díaz
>> Software Engineer
>> Córdoba, Argentina
>> Skype: markdiaz22
