[NEW BSP] Mbed lpc1768 board
Sebastian Huber
Fri Jun 6 14:31:50 UTC 2014
On 2014-06-06 16:25, Marcos Díaz wrote:
> Sorry, i didn't understand what is the new coding style we are adding.
You use for example four space characters for indentation and sometimes align
function parameters in this way
+static inline uint8_t lpc176x_uart_get_register(const uintptr_t addr,
+ const uint8_t i)
+ volatile uint32_t *reg = (volatile uint32_t *) addr;
+ return (uint8_t) reg [i];
or this way
+rtems_status_code lpc176x_gpio_config(const lpc176x_pin_number pin,
+ const lpc176x_gpio_direction dir)
You use
+ if ((pin < LPC176X_MAX_PORT_NUMBER) && (dir < LPC176X_GPIO_FUNCTION_COUNT))
+ const lpc176x_gpio_ports port = LPC176X_IO_PORT(pin);
+ const uint32_t pin_of_port = LPC176X_IO_PORT_BIT(pin);
and also
+ for(i=0; i < function_vector_size; ++i)
so not "for (". Sometimes a space between operators, sometimes not.
You use
+ typedef struct
+ * @brief Pin board.
+ lpc176x_pin_number pin;
+ * @brief A function that attends an interrupt for 'pin'.
+ lpc176x_gpio_interrupt_function function;
+ } lpc176x_registered_interrupt_function;
So all in all is different to what we have, but we have so many styles in the
BSP area, it doesn't matter.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
